Question about Whirlpool Washing Machines
Whirlpool top loan washer...will not spin all of water out of machine Washer is approximately 10 years old..
    Brigadier General:
  • 6,277 Answers
It's actually the drain motor which empties the water at each cycle, including that which the spin releases from the garments.
To see what is happening here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 12, 2011
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
Sm8280871 is the model listed under the lid. It is a Roper by Whirlpool top load washer about 10 years old. I can hear the motor however the washer does not spin, or drain. It appears that it tries to...
I suspect the V belt is worn out try taking the side cover off you would have to tilt the machine another helper maybe needed make sure you drain the remaining water out and unplugged the cord safety first
Oct 24, 2013 | Roper RAK2751WWH Top Load Washer
Whirlpool top loader washer will not spin
Could be one of several different things depending on the age and model. If its less than 10 years old and is a top load washer its probably a motor coupling (connects the motor to the transmission kinda like a belt) or lid switch. If the water is draining out but the washer is not spinning its probably the motor coupling. If it still has water in it and won't spin, its probably the lid switch. If your washer is a front loader there could be several things going on. Hope that helps.
Aug 29, 2011 | Whirlpool Washing Machines
Whirlpool ultimate care extra large, about 10 years old. when the machine is in spin cycle, it throws the circuit breaker. It started with a heavy load, but now it seems to do it all the time. It started...
Water leaking from tub seal into motor possibly? Try doing spin with dry newspaper under the machine and check for leaks. Could also possibly be water heater element loose or breaking down - leaks from drain hose or water pump body into windings? Dry news paper test should highlight where leaks are coming from.
!0 years old is ancient for a machine and you might consider replacement rather than a repair which will only be throwing good money after bad. Do you drive a 10 year old car? if you do, you expect repair bills to mount up! same with washer. I bet it doesn't owe you much!
Jan 03, 2018 | Whirlpool LSW9700P Top Load Washer
Need APPROXIMATE water consumption on 10 yr old Whirlpool washer
Hello. The older top load washers use up to 60 gallons of water per load. That said, also check your toilets as a leaking toilet can use tens of thousands of gallons per year. Here is a link that explains how to check your toilets and other items for leaks. Regards, Joe
ps - kindly rate my answer as helpful. thanks.
Feb 17, 2010 | Washing Machines
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
Breaker switch flips when machine starts to agitate
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Aug 20, 2009 | Whirlpool LSB6500P Top Load Washer
F1 error on Whirlpool cabrio
it means that the control board is not sensing the water pressure (this tells the machine how much water to put in the washer) in my experience you have to replace the control board which will cost over 200 plus labor which will be over a 100
Dec 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
12 people viewed this question
Dan Webster
Dan Webster
Sal De
