Question about Toshiba Satellite A55-S1063 Notebook
Fluttering glitchy screen
Hi, how can I switch to using a different monitor, since the one on my 2 yr old A55 is all fluttering and blinking with horizontal lines, and a dark spot in the lowest right corner..It's very hot down there too.
  • emmerich Nov 19, 2008
    I am getting a pink screen then the whole screen will flutter with lines so I can't see or do anything. Someone said a new video card would fix it but I want to be sure before I do that.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 168 Answers
If your laptop supports dual monitors then it's a pretty easy fix. Plug in an external monitor and secure the screws. reboot your system and it will recognize the external monitor and set it up as your main monitor. you now have access to all your files w/o the cost of replacing your laptop screen (which would cost about as much as a new one). ^_^
Posted on Sep 13, 2009
When my Rinnai ES22 tries to start it makes a fluttering noise and then blinks 11
The fluttering noise you are hearing is an improper gas air mixture. Make sure the vent termination is clear of any debris. You could have improper gas pressure due to a frozen regulator. If the issue does not clear, contact your gas company.
Mar 07, 2011 | Heating & Cooling
Screen wiggles off and on
I took the advise of someone who wrote in and checked my refresh rate. I found it was at 60 and was advised to change it to 75. So far I haven't experienced any fluttering or wiggling so am hoping this will do the trick. I also checked all the plug in's that were connected to my power strip to make sure they were o.k. I still have one year left on my warranty so may have my monitor checked out just in case I've missed something. Thanks for your offer. I'll be sure to save your website for future questions.
May 30, 2009 | Gateway FPD1760 17" LCD Monitor
Flutterin sound in tv
try turning the bass down and see if this helps the fluttering. If it does help a little most likely it is a blown speaker. Can replace at radioshack for under 20 dollars. It is hard for me to tell since i am not there to diagnose but also can you do a balace to go completely to the right with bass up and see how it sounds. now with bass up turn the balance to go to left speakers. if you hear fluttering from one side that means a speaker or speakers from the side that is fluttering need to be replaced. i hope this helps and good luck fixing this.
Feb 21, 2009 | RCA Televison & Video
Fluttering
sounds like bad controller.
Jul 09, 2008 | 1991 Honda Accord
Hp monitor
Sounds like the video card, but could be the ccfl inverter starting to go bad or a ccfl lamp going bad.
srich
May 27, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Horizontal won't stop fluttering
call tech and suggest to repair the horizontal drive ..
Nov 16, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Fluttering and picture discoloration
model # VS-60607 Mfg Yr February 2000 Big Screen TV:
1.  tearing/fluttering/ripping across entire screen caused by damages associated with diode 522, and;
2.  the problem is really an OEM Mitsubishi causation as the
leads of said diode get too hot <too much current flowing through
it> and this component lifts itself off of the main circuit board, &;
3.  supplemental hidden damages arise from this, and;
4.  you should not attempt to fix this set but rather contact the
national & state Consumer Protection staff & file a complaint, &;
5.  pleadings should say:
    a.  this set almost burned down our/my home & us to death;
    b.  we paid too much money for this to happen, and;
    c.  we demand full replacement of the set & money for our
         inconvenience for all of the above, and;
    d.  said replacement need not be a Mitsubishi but like unit;
6.  check with Martindale-Hubble to find a good law firm/lawyer.
7.  have fun, eh!
Oct 07, 2007 | Mitsubishi VS-60607 TV
THE SCREEN IS GREEN AND SHIWUNG LINES AND GRAINS
Samsung Customer support will advise - depending on the age of this model Anew camera may be the most economic answer
Aug 01, 2007 | Samsung Digimax S500 Digital Camera
Horrizontal fluttering when warmed up.
1. HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB
Oct 18, 2006 | Mitsubishi VS-60705 60" Rear Projection...
Toshiba Satellite A55-S1063 Notebook Logo
426 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
