Sqeaks while spinning - Washing Machines
  • 1,606 Answers
The tub or clutch bearing could be going bad. If you see evidence of water leakage under the machine or on top of the transmission under the tub, it's definitely the tub bearing.
Posted on Mar 12, 2011
I have a 2000 dodge caravan 3.0 engine there a sqeak noise when i first crank the motor up until it warms up i replaced the idler pully 6 months ago but it still sqeaks i can move the tensioner pully a...
I can't say for sure but it could be the tensioner pully. I don't think you should be able to move it side to side. That would indicate that the bearing is worn.
Nov 03, 2017 | 2000 Dodge Caravan
My fisher paykel top loader smart drive 053 has started to sqeak when spinning
drive belt may be loose and squealing just like a car will suggest re placeing it at that age.
Jul 09, 2012 | Washing Machines
Bernina 140 which has a sqeak in its Handwheel How do I fix it
it's sounds like the machine needs to be serviced when they start sqeaking or making odd noises
Mar 06, 2012 | Bernina Activa 140
Sqeaks and won"t spin
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 24, 2010 | Whirlpool LGR5636L Gas Dryer
Sqeaks when spinning and washing - intermittently.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Loud sqeak while spinning dryer works otherwise
could be the bearings on the agitator or motor or rubber seal is dry and squeaking
Dec 22, 2009 | Dryers
No picture or sound only a squeaking sound
The sqeaking noise is probably the color wheel spinning. The reason for no picture or sound could be high voltage transformer or power supply or other bad circuit on the control board. You can test it with an ohmmeter 25 ohms and 5 volts
Oct 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
Dryer makes a lot of noise when spinning, sqeaking, etc.
hi thanks for the question it sounds lie the front glides are worn & te back bearing check those parts
Sep 27, 2008 | GE DBXR463EBWW Electric Dryer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
