Question about Roper Dryers
My Roper dryer ran a cycle with no heat then when I turned it off and tried to turn it back on...it will not come on at all. What might be the problem, I have checked the electric source and it is fine.
  • 55 Answers
Hello, It is possibly the thermal fuse. Be sure to clean out the vent hose and the vent pipe to the outside to prevent over heating. If the vent system is ok then replace the thermostat as well as the thermal fuse. You can goto - http://www.searspartsdirect.com/partsdirect/index.action - to buy parts and get a parts breakdown of most brands. Just enter your model number and select model search.
Good Luck
Posted on Mar 12, 2011
Roper dryer red4440vq1 not drying after changing internal fuse, internal bias, high limit thermostat and thermal cut off and cleaning vent, element heats up to temp and cycles
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Sep 15, 2017 | Roper Dryers
No Heat, No Airflow
Need to replace the timer.
Dec 09, 2013 | Roper REX3614KW Electric Dryer
I have a roper dryer. I took it apart today
Remove all duct work connected to this dryer. Clean thoroughly. You will find amass of lint inside of it causing your problem. If not the moister sensor is not working properly and needs to be replaced.
I do hope you will find a clogged vent tube for it is easier to clean the tube than to replace the sensor. The sensor is a fail safe part. It keeps the dryer from catching on fire when the lint tube is clogged up
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Heat is not always coming on in dryer. Roper dryer from Lowes
There are numerous temperature sensors on the dryer. Some are near the drum, some could be near the lint filter if it is located inside the dryer door. Try changing these first as they are an in expensive fix. It could also be the heating coils themselves. Highly unlikely it would be the dial, unless the dial was accidentally turned in the wrong direction.
Apr 26, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer gets hot and turns but the heat is
remove the front cover of the unit and make sure the dryer wheel is hooked and turning,while in there check for any pipe ductwork thats disconnected
Feb 27, 2010 | Roper RES7646KQ Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer model res7648kq0. wont turn on or heat ?
On the back side of the dryer sits the heater and various safety clixons. Any of them that would be OPEN ( no continuity) would be the problem. Here are some repair pictures
Jul 25, 2009 | Roper RES7646KQ Electric Dryer
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Jan 20, 2009 | Roper REX3614KW Electric Dryer
NO HEAT
CK IF YOU HAVE 220V COMMING IN OR THE HEATING ELEMENT IS GOOD. OR CK THE THM FUSE.IS NO GOOD. BUT IF DRYER RAN OVER NIGHT AND DIDNOT TRUN OFF YOU HAVE TIMER PROBLUM. THE DRYER SHULD TRUN OFF EVEN YOU HAVE HEAT IN THE DRYER OR NOT.
May 03, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
43 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
