Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Control panel lighs blink and ice door opens and shuts. The fridge and freezer is still cold. I called Maytag and they are sending me a new circuit board. The local Maytag store owner told me to disconnect the wire on top of the door connection to keep the unit still cold. Are they sending me the control panel board in the front or the high voltage board in the back? Do I need to change both? I hear there boards for these years are bad, but not listed on recall pages. Where can I find an installation guide? They told me instructions will come with the board, but I just wanted to check ahead of time before it comes. Thank you, Matt Carman, Gilbert, AZ mcarman8@cox.net
  • 4 more comments
  • jonclairgonc Aug 21, 2008
    I too have the same problem. What should I do?
  • brenthomoles Sep 28, 2008
    front door lights 'possesed' blinking on and off, ice door opening and closing.
  • Anonymous Oct 06, 2008
    MINE STARTED LAST NIGHT. I TRIED UNPLUGGING AND PLUGGING BACK IN TO MAYBE RESET THE MACHINE, DIDN'T WORK. IT STOPPED FOR A FEW MINUTES AND STARTED AGAIN.NI THOUGHT MAYTAG WAS SUPPOSED TO HAVE BETTER QUALITY THAN THIS.
  • Anonymous Nov 13, 2008
    Same problem here.
  • Anonymous Dec 11, 2008
    Came home today to find the temp displays flashing and the ice door opening and closing, I bought this 6 months ago
    Came home today and found the temp displays flashing and the ice door opening and closing, I bought this 6 months ago
I just called Maytag (now Whirlpool) @1-800-253-1301.  They are shipping me a free control panel and are also paying for a certified installer to come to my home to do the exchange.
I told them when I called that I learned from the internet that it was a quality issue and they did not disagree.  They processed the order and offered the installation without me asking.
My refrigerator is out of warranty so they covered it as a quality issue.  We enjoy our refrigerator and have not had any other problems accept when we first received it and someone had to come and adjust the icemaker.  Yes the icemaker is small by some standards but it meets our needs. When we need lots of ice, for guests we just buy a bag for less than a buck.
Great service response from Maytag.  Thanks.
Posted on Nov 20, 2008
This is the complete solution. click on the refrigerator at this website. basically there are two bad capacitors on the control circuit board in the rear of the unit. this website (THANKS!!! to the author) has detailed instruction as to the fix.
http://www.liny.net/MaytagIce2O.htm
Posted on Sep 28, 2008
Model # MFF2557HES Top refrigator section stoped cooling freezer is working
You may have Ice buildup in the freezer. You freezer has a fan in the bak that sends the cool air to the fridge. Your fridge dial determines how muh cold air comes from the freezer. Try defrosting the freezer. You may have to pull the back panel off of the inside of the freezer to get the ice thawed. The ice build up is likely causing the air to not get to the fridge. Hope it works.
Aug 16, 2012 | Maytag MFD2560HES Bottom Freezer French...
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
My maytag fridgerator has suddenly stopped getting cold. My freezer is fine and stays cold. Troubleshooting it did not work. Please help.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it'll be the control.
Jul 30, 2011 | Maytag MBF 2256 Bottom Freezer...
Refrigerator section which is on the top is not cooling, however the lower freezer section is working and making ice. Fan in refrigerator section does not seem to be working. Maytag mod#mbf2254HEW
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. The fan should spin freely when you spin it. You can check the fan plug for voltage to see if it's getting power with the door switch pushed in. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Dec 26, 2010 | Maytag Refrigerators
My fridge wont get cool
Jul 12, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
MSD2756GEB maytag. freezer is working properly.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 21, 2010 | Refrigerators
Freezer gets cold refrigerator doesn't
check the damper door located between the freezer and refrigerator compartments(this lets in the cold air from the freezer) and make sure it opens and closes with your temp adjustment in the refrigerator compartment,sometimes they ice-up and are frozen in one position then take a hair dryer and defrost the door
Mar 13, 2010 | Maytag MTF2156GEW Top Freezer Refrigerator
The ice trap door won't stop cycling open and closed and the control panel on the door is blinking all of the lights
Called maytag with model and serial number. This is a very common problem. They sent a new mother board free of charge within a couple of days. You will have to go to the back of the fridge to swap mother boards. It was pretty simple if you have a little patience. Maytag wanted to charge $200 for the service call but it took my husband about twenty minutes. Then you will need to reprogram with the code inside of the door. I was told that this happens alot if there is a power surge, so I now have the fridge on a surge protector. Haven't had a problem since. Hope this helps.
Nov 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Ice20 refrigerator
You have a bad high voltage board and as the other user said call the manufacturer they are assisting with this problem.
Jul 09, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
365 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
