Question about Dometic Rooftop RV Air Conditioner
Have a 2009 34' Cougar 5th wheel with a roof mounted A/C with an internal Dometic thermostat. When I turn the AC off at the thermostat, the fan quits blowing but I can still hear the compressor running. I have to trip the breaker to get turn the compressor off. Running on "auto" the fan will quit but not compressor...does cool. Is there maybe a stuck compressor relay??? Where is it? On the roof?
  • 1,420 Answers
Sounds like a bad contactor. The contactor will be near the compressor on the roof.
Posted on Mar 12, 2011
I have a 2011 cedar creek by forest river 5th wheel and the dometic roof top ac thermostat is giving me an error mesg E4. what does that mean?
somehow somebody activated zone 4 cannot see zone 4 make sure all dipswitches correct if new or if old reset thermostat
Jul 25, 2017 | Dometic Heating & Cooling
I have a Dometic 15K roof Ac on my FW. After the AC reaches therm temp, the compressor and the fan turn off, but the fan starts right back up again and runs until you set the thermostat on off.
That is normal operation, only the compressor cycles, the fan stays running to keep air circulating for better temp control. Otherwise the rear of the space could get 5 degrees warmer than the front
Feb 23, 2015 | Dometic 459516 459516.XX1C0 Brisk Air...
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
My Dometic AC is mounted on a sloped roof (as are a lot today). However in humid weather when the AC is putting out a lot of water, the fast speed of the fan pulls water out of the evaporator pan and...
Clean air filter and evaporator coil periodically. And also insulate tightly for the pipelines including drain pipe also. The heat hose observe the water over the pipelines and evaporate. Thanks and helpful?
Jan 17, 2011 | Dometic Rooftop RV Air Conditioner
AC and furnace turn on and off frequently.
Your unit is short cycling. Most likely suspect is the thermostat is mounted in direct line with the discharge air. Adjust diffuser away from stat or relocate stat.
Oct 02, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
563 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
