Question about Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel
White maytag gas and broiler wall oven is flashing F 7, what does it mean?
  • Maytag Master
  • 1,902 Answers
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Mar 12, 2011
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
I smell gas when I turn on my oven. I replaced the gas line but have the same result.
Your Maytag wall oven is equipped with
pilotless ignition. Heat from the Glow Bar
ignitor lights the oven burner. With this type of
ignition system, the oven will not operate
during a power failure or if the wall oven is
disconnected from the wall outlet.
if it is plugged in and everything, your glow bar may be broken, which would mean you will either need to replace it, or get professional service.
Dec 25, 2010 | Maytag CWG3100A Gas Single Oven
Bottom burner for maytag gas oven will not light. The broiler will turn on and heat, but not the bottom burner.
will have to replace the oven ignitor part #120000035 / this will correct burner problem / mm
Dec 08, 2009 | Ovens
Oven won't light.
Localwonder gave a more comprehensive answer, but I wanted to share my recent related experience too:
Same model: MGR5750BDW
Oven was not heating up, or would sometimes and not others. Broiler worked fine. The nice thing is that the broiler igniter and the oven igniter are the same part. So I swapped them until I could get a replacement part.
Before I did anything, I turned off the gas!
To take out the broiler igniter: there's one screw right near the front of the oven that holds the burner assembly in place. Remove that, gently pull the assembly off the gas nozzle off to the left. Then where the wires from the igniter go into the back wall, remove the screw that holds the little door, remove that little door, and then gently pull the wires through until the connector comes through the opening. I also found you can go behind the stove, remove the back panel (which is easy) and see the igniter's connector.
The oven one: remove the floor of the oven by lifting it at the back, and then lift it out towards the back of the oven. Then you can see the igniter at the back of the floor of the oven. remove the two mounting screws, and then gently pull the wires until the connector comes through the insulation.
The bad igniter looked like it had burned down to bare metal in a big patch...not sure if that's the actual problem, but in any event, I installed the good igniter in the bottom (gently pushing the reconnected connector through the insulation, and feeding as much of the wires down in there as well), and the bad igniter in the broiler position (since that was the easiest one to access and replace, it'll be easy enough to replace when I get the parts). Tested, and everything worked great. And I could watch the bad igniter light up, and never light, confirming that it was the igniter itself that was the problem.
The best part, for this stove anyway, -- the ONLY tool needed was a #2 phillips screwdriver. Really. All told, maybe an hour of work, nothing intense. And free -- so if they both worked, it would have spared me ordering a part that didn't need to be replaced!
Jul 22, 2009 | Maytag Amana 30 in. Electric Double Wall...
What does the F7 code mean on my Maytag 24 In Gas Wall Oven with Broiler''
The Function key is shorted or stuck. Replace the touch pad or if touch pad is part of the clock, replace the clock (ERC).
Jun 20, 2009 | Ovens
Wall oven will not light
Remove the flame spreader panel to access the ignitor.
Place a clamp on amp meter on the ignitor wire and turn the oven on.
If you read less than 2.9 amps, replace the ignitor.
If you read 2.9 to 3.2 amps replace the gas safety valve.
Mar 28, 2009 | Maytag 24" Built-In Single Electric Wall...
Oven will not work - Hi/Lo broiler works fine
you have a bad bake ignitor. it is mounted to the long tube in the very back wall of the tube. usually held on by 2 1/4 inch bolts. usually if you replace the ignitor you have to cut the old one off and hard wire the new one in depending on what the new connection on you ignitor look like.
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Fridgidaire FGF 374 CCSA oven and broiler do not come on
F1 means it is a defective eeprom. The software is incorrect. Replace EOC. Check inside the bottom drawer on the right side: there was an envelope with the troubleshooting and maintenance diagrams in it.
Jan 21, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag 24" Built-In Single Gas Wall Oven - Stainless-Steel Logo
225 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
