Question about Miele KFN8462S Bottom Freezer Refrigerator
WHAT WOULD CAUSE THE TEMPERATURE TO DROP FROM18ON MY FREZZER BENEATH FRIDGE
  • rosehill2005 Mar 12, 2011
    and then stop flashing
How can i operate the temperature of the haier fridge model hrf-660aa
do you hear the compressor come on? can u feel it vibrating? if not? bad relay maybe? is there power from the outlet? may also have a bad cold control thermostat or defrost timer? is ther any heat in the freezer compartment?
Feb 16, 2015 | Haier Refrigerators
Frezzer door left open all contence ruined red light what do I do now
defrost and clean out the freezer and refrigerator (empty completely). , unplug. turn the temperature selector to 0 . plug back in turn the selector to the preferred temperature and it should work again. Do not forget to also clean the surplus water collector in the back of the fridge if its full.
Jul 01, 2014 | Hotpoint FFA70 Bottom Freezer Refrigerator
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge is freezing
What type of fridge do you have? What is it set at?
Sometimes I accidentally bump into the temperature dial and the fridge becomes too cold.
Mar 09, 2012 | Fisher and Paykel Refrigerators
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
FRIDGE STAYING AROUND 25 DEGREES
you have a gas leak , a refrigeration mechanic is required.
May 10, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator Keeps Running
A fridge normally runns for 16 hours a day, it sounds like it does exactly that. It is doing everything it serpose to. Is there anything else that it is doing? If you can give me any information I will try to help. But it sounds fine so far
Please let me know
Jan 11, 2009 | Refrigerators
DRAIN BLOCKED WITH ICE
It sounds like you need to install a drain heater. Sometimes these are available as a kit from a parts dealer, and sometimes you can just take a piece of bare solid copper or aluminium wire and put it a little ways down the drain, then wrap the other end around the defrost heater, so that when the fridge goes into self defrost, it keeps the drain warm so it does not freeze. The better way to do this repair though is to see if a drain heater is available for you model as a direct fit part. The other way is only to be used as a last resort. Good Luck!
Oct 10, 2006 | Samsung SRS20DTD Side by Side Refrigerator
Miele KFN8462S Bottom Freezer Refrigerator Logo
43 people viewed this question
Top Miele Refrigerators Experts
AJMAL KHAN
JonSnell Electronic
JonSnell Electronic
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
