I have a Whirlpool LSR7233 Top Loading Wash Machine We smelled something burning and the machine completely has stopped. It is filled with water and clothes. How can I drain the machine? ANy ideas on the problem?
  • 55 Answers
Here is a trick I use often using a garden hose. Remove the clothes of course. put the male end of the hose into the tub and make one coil around the agitator.You may have to hold it down in the bottom or weight it down and you may have to use a couple hoses depending on you home. With the other end still hooked to an outdoor faucet turn the water on just long enough to fill the hose. Turn the faucet off and disconnect it, lay it on the ground. keeping the entire length of the hose lower than the top of the washer it will slowly siphon the water out of the tub. Good Luck
Posted on Mar 12, 2011
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
The Speed Queen Top Loading Washing machine used by my condo doesn't drain completely after the wash cycle. It normally leaves half of the wash water in the tub then fills the rinse water on top of it. ...
You are absolutely right, whoever told you otherwise is full of ____!! The wash water has to completely drain out and if it isn't there may be an obstruction of some kind in the pump if this is happening all the time. It could be a child's sock, or a bra wire, something like that. Have someone reputable check it out for you.
Jan 24, 2010 | Washing Machines
Load was placed into the washing machine. the
There are many causes for your problem. The cover switch may not sense that the cover is closed. The timer may not be working properly. There could be a burned out motor or wire broken. If it sounds like it is running but not then it could be a broken or slipping drive belt. I suggest that you get a repairman to check it out and repair it.
Oct 08, 2009 | Kenmore Washing Machines
Washer smells like something is burning and it won't work at all
i would check the motor, and also the coupler that mates the motor to the tranny
Nov 26, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washer just stopped
I would check the drainpump ans see if there is something jammed inside like a coin or screw,nail etc before doing anything else .Unplug the machine first though . A burning smell will occur with a load of water trying to spin .
Nov 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Top Loading whirlpool washing machine.
Could be the top lid switch. If the timer has stopped moving (you can no longer hear it clicking along) good chance that's what it is. When it has stopped try pushing hard down on the top of the lid AND/OR put a piece of plastic (or something ) into the lid latch switch... See if it continues on with the wash cycle...
Mine just went bad this week. Bought the part for $25...
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Musty smell
probaly a good wash with chlorine bleach..fill tub with hot water pour 2-3 cups bleach let agitate for few mins stop machine and let set 20-30 mins restart and let finish cycle ..to head of future problem leave lid open between uses
May 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
