Question about Black & Decker Hedge Hog 22-Inch 2.8-AMP Dual-Action Hedge Trimmer #HS1012
My 22inch Hedge Hog trimmer (model cht500) 14.4v blades are moving very slowly. Purchased another charger but that did not help the situation. Any thoughts -battery need replacing?
  • 4 Answers
Possably the cells in the batt r warn out, take the battery appart nd charge nd c if they r holding charge, if they are you can buy them from a shop on ebay which is really cheap, there probably 1.2 volts, 1400 mha which is tiny. ive got 6800 mha batts in my hedge hog
Posted on Mar 25, 2011
My electric hedge trimmer blades do not move when it is turned on. Suggestions? hs2400 date code 20021249
Check that the bolts or screws holding the two blades together aren't too tight preventing the blades sliding. Lubricate the blades also with WD40.
Jul 14, 2011 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Need diagram of blade assembly for Hedge Hog HS 2400 Type 1. Need to know how the spacers and eccentric are laid out between the blades.
try hulufile.com its a good source for pdf manuals on 2 stroke machines. i hope you find this useful as i use them alot ..
Nov 23, 2010 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
I have a 22inch Craftsman Hedge Trimmer, Model No. 315.81591. When trimming a hedge near a chain-link fence, one of the steel links from the fence got caught between the blade guard and the cutter blade. ...
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Sep 27, 2010 | Craftsman 22 in Hedge Trimmer
Cutting blade for 8124-04 Type 5
Do not try and replace the blade.
They are not ment to be replaced let alone even resharped
If it can not cut any more time to buy a new model
Jul 21, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
My hedge trimmer blades do not move when I turn it on
Check the power wires that connect to the motor. My 18 inch B&D hedge trimmers both had loose wires at the motor that had to be re-soldered. You will need to open the trimmer casing to get to the loose wires, if that is the problem.
Jul 09, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Hi! There is power to the unit....the blades don't move.
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Jun 08, 2010 | Black & Decker Hedge Hog 20-Inch 2.8-AMP...
Black & Decker Hedge Hog 24-Inch Hedge Trimmer. Motor runs, but blades don't move. Is there a sheer pin that I can replace, or is the thing bound for the dump?
You can definitely pick up a sheer pin for that model. I know ereplacementparts.com has them usually pretty discounted, or just check out a local store, but make sure they are in stock.
Apr 27, 2010 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Do I ever need to sharpen? If I do, how?
Hey i found this for you i might help. Click on the link at the bottom!!
How to Sharpen a Black and Decker Hedge Hog sharpen-black-decker-hedge-hog-800x800.jpg Maintaining the sharpness of electric timmers can made landscape trimming easier with beautiful results. Electric hedge trimmers make trimming hedges and bushes easier and quicker than using manual hand-powered trimmers. Electric trimmers, the most popular type in the U.S., cost less and require less maintenance than gasoline-powered models. Electric trimmers are used most often by homeowners with the Black and Decker Hedge Hog series being very popular. While they are not premium products, electric trimmers like the Black and Decker Hedge Hog trimmer can keep trimming reliably for years with proper maintenance, including sharpening the blade's teeth.
Difficulty: Moderately Easy Instructions Things You'll Need
  • Work table
  • Two medium size clamps
  • Dremel tool or similar hand-held multi-purpose tool
  • Grinding wheel attachment for hand-held tool.
  • Dremel 971 (or similar) aluminum oxide grinding sharpening stone with a tip small enough to cover the flat facet of a Hedge Hog blade tooth
    • 1 Unplug the electric trimmer before trying to sharpen the teeth.
    • 2 Clamp the electric trimmer to the work table using two clamps if necessary so the Hedge Hog is firmly held down with the blade teeth accessible over the edge of the work table.
    • 3 Insert and secure grinding tip in hand-held multi-purpose tool.
    • 4 Maneuver the grinding tip so it is perpendicular to the facet of the Hedge Hog tooth.
    • 5 Sharpen teeth in one direction, being careful to try and maintain the same cutting edge angle on the sharpened tooth of no less than 35 degrees.
    • 6 Make same number of grinding passes/grind the same length of time a few seconds on each tooth.
Tips & Warnings
  • This task should take about 15 minutes.
  • Keep a light touch; too much force can break the grinding surface.
  • For best results, insert the sharpening bit slightly less than all the way into the tool.
Read more: How to Sharpen a Black and Decker Hedge Hog ' eHow.com http://www.ehow.com/how_7163131_sharpen-black-decker-hedge-hog.html#ixzz1XsAosvvl
Oct 17, 2009 | Black & Decker Hedge Hog 24-Inch 3.0-AMP...
Describe your Black & Decker Hedge Hog
You may have a piece of metal between the moving blade and the stationary one. Also the motor may have been at the top of the stroke when it stopped. You may be able to "force" the blade to move a little. This may free it enough to work.
Jul 14, 2009 | Black & Decker Hedge Hog 22-Inch 2.8-AMP...
Black & Decker Hedge Hog 22-Inch 2.8-AMP Dual-Action Hedge Trimmer #HS1012 Logo
290 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
