Question about Viking Designer DGSU1004BSS Stainless Steel Gas Kitchen Range
Two gas valves on my viking DGSU1004BSS are stuck. I assume that I will have to replace them. How do I remove the top?
3 Suggested Answers
SOURCE: I have a 30
call a viking repairman
Posted on Nov 18, 2009
TheMobilian
  • 8220 Answers
SOURCE: I have a Viking Gas 30
Viking manual
Posted on Jul 21, 2010
How do I access the gas safety valve for the infrared broiler on Viking VGRC485
under front access toe panel. Remove doors on both sides and remove screws, obviously unplug unit and your valve will be right there between both ovens.
Oct 10, 2013 | Viking VGRC485-6 Gas Kitchen Range
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Apr 22, 2011 | Viking 27" Professional Select Built-in...
How do I replace a broken stem on the griddle knob of a forty-eight inch Viking range?
You would remove all of the knobs and then you remove the screws holding the face panel on there. Then you can access burner valves. The new part may not come with a preset orifice because the factory does not know which type of gas you have. So what they do is tighten the orifice all the way down. Lets see if I have a viking service manual:
Viking Stove Manual
Viking parts outlet
Oct 29, 2010 | Viking Kitchen Ranges
How do you access the ignitor wires for the
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range.
Apr 08, 2010 | Viking VGIC485-6G Gas Kitchen Range
How do I access a spark ignitor on a Viking gas
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by a 'tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and would cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range. Of course you need to ensure it is the correct one for your stove. The ignitor you remove should have a manufacturer part number on it. No calibration required on mine - a sealed electronic unit. Probably about 10 wires that need to be R&R'ed - they are on with reuseable fasteners.
Jan 18, 2010 | Stoves 600SiDOm Gas Kitchen Range
How to install ignitors on Viking Range
Sep 07, 2009 | Viking VGIC485-6G Gas Kitchen Range
Viking range - gas flame on one burner does not change
It sounds like the repair man was correct. The only variable is the valve, if the rest of the burners are fine then it will be the valve
Jan 28, 2009 | Viking VGSC366-6B Gas Kitchen Range
Viking Designer DGSU1004BSS Stainless Steel Gas Kitchen Range Logo
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
