Just purchased and HP P2055dn. Have wireless router in basement. Want printer upstairs. Can I connect the printer to the network with a wireless USB adapter? If yes, are there any particular steps I need to follow? BTW -- printer not yet connected to anything. Thanks Bob
  • 1,915 Answers
You should have no problem using a wireless USB adapter, just follow the steps that come with the adapter.
Posted on Mar 12, 2011
I live in a three story house my wii is in the basement and my wireless router is on the second floor should my wii pick up a signal...i tried to hook up with netflix and my wii says cant find connection
Hi.
1. Try using it upstairs on the 2nd floor and if it works there you know its a range issue with the router.
To then solve it you could run a cable from the router down to the basement (which is a bit old school but very effective and guarenteed to work) or get a second router or modem and place it in the basement. (for modem you would need a phoneline in the basement)
2. If it doesn't work upstairs, make sure you have the correct connection information for your network and that your network is broadcasting its SSID. If your network is not broadcasting it is what is known as hidden. This means that you will have to enter all the network information manually by following the prompts on the wii console.
Jun 16, 2011 | Nintendo Wii Console
How do I connect my HP 8250 Wirelessly? I have a router and a Linksys wireless-B adapter.
Make sure your router is set to accept Wireless-B connections...most aren't. Log into your router and setup wireless, using an SSID and security. Then connect with your laptop and you're good to go.
Mar 12, 2011 | HP - HP Photosmart 8250 printer
I keep losing my wireless connection inside my home. My modem is in the basement and I want to use my laptop upstairs. I use an N router and have cable internet. My house is also wired with Cat 5 wiring...
Well , the connection upstairs depends on the capabilities of the router that how much coverage it can give for the wireless clients associated.
Since , it is a N-router so try upgrading the drivers for it , the technical term will be firmware.Upgrade the firmware of the router to the latest one and you might have your issue resolved.
Nov 24, 2009 | Computers & Internet
I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
The wireless card in the computers will show a low signal strength.
Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
Nov 07, 2009 | Linksys WRT160N Wireless Router
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
HP photosmart C5580 wireless printing problem
You laptop will not be able to connect to the printer using the bluetooth technology. But the good news is that you can use the printer thru your home network by having the desktop that the printer is connected to be part of the same home network that your laptop is part of and then share your printer on our desktop and then select it as a printer to use on your laptop.
This link has instructions for all of your home network instructions.
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
Aug 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Quick Question regarding a set up
correct you only need a wireless card or usb adapter is it a laptop or desk top unit? in any case a wireless adapter should do just fine
May 04, 2008 | Linksys Wireless-G WRT54G Router
D-link router DI524 using next G external wireless modem
You can purchase a usb wireless dongle and attach to the PC. From then onwards you can set up a wireless network without connecting the usb cable for the router. The dongle will enable wireless capabilities on the pc. The only thing left is to have all devices running in the same workgroup.
Mar 09, 2008 | Computers & Internet
Connecting 3050 to router...
1} At first configure ip to printer as per u r setup.
2) connect ur desktop to Router (it should be ping)
before doing that ur router should be configured properly Fast Eathernet port 0/0,or as respectively
3) then start u hp setup CD in u r machine.
4) it will run and detect the printer.
Oct 24, 2007 | HP LaserJet 3050 All-In-One Printer
106 people viewed this question
jasbo
jasbo
