Question about Dishwashers
I have a crs 66a and it will not fill with water at all i am wanting to no if the water solinoid is keeping the dishwasher from fill with water , i have check the water filter before the dishwasher and there is water going through the filter up to the dishwasher and the pressure gauges on the dishwasher are showing water pressure but there is no water entering the dishwater when you turn on the dishwasher
    Problem Solver:
  • 17 Answers
HI,
Check the coil of solenoid if is energised..
If not..is the float switch that close the circuit in order to activate the solenoid..
Good luck
Posted on Jul 01, 2013
  • 55 Answers
It could be the solenoid or water level float. Hobart is probably the only place to find parts. http://hobart.co.kr/manual_pdf//RS22A(May-01)-parts.pdf
http://www.hobartservice.com/
Good Luck
Posted on Mar 12, 2011
I have a whirlpool quiet partner 2. It won't fill with water. I have tried the trick to push heated dry/Sami over and over, but won't fill!! Help please!
Check for a solinoid valve under the machine. This shifts the pump from fill/wash to drain. Sometimes the slug in the coil gets stuck or rusted. Also, a float switch tells the water solinoid to open.
Dec 31, 2014 | Whirlpool Dishwashers
No water in Bosch dishwasher
You should get 110v if you meter across the 2 wires while not on the solenoid. A lot of machines now switch neutral to keep the amperage down. So you may not have voltage because no neutral has been switched in the controls ( timer or board). Solenoid may be ok 1000ohms is about right. You can try making a test lead and just switching on the solenoid.
Jul 10, 2013 | Dishwashers
I have a Whirlpool Dishwasher model no. ADG 6340 IX.The inlet valve is pulsing and letting in water on every pulse. It just keeps filling, over fills and trips elcb
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Jun 05, 2011 | Whirlpool 24 in. ADG6340iX Built-in...
I have a Kenmore Dishwasher Quiet Guard 1 Model Number 665.1784440. It will not fill up with water, but it will drain if I pour water into it. Help
start simple, make sure water supply is ok. if this ok i would be lookin at the inlet valve, its solinoid could be faulty. located inside dishwasher where water hose screws on.
also on dishwashers a broken wire inside the door skin where wires loop into bottom would be fairly common.
Sep 25, 2010 | Dishwashers
How to install a water solinoid
Check under your dishwasher usually on the front left corner... there are just acouple of screws and a couple of hoses to change to replace this.. actually a fairly simple deal.
Just check out my tip for how to buy parts online and the tip on the valve...
Here they are...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Apr 05, 2010 | Samsung DMR78AHS Builtin Dishwasher
Dishwasher was making whirliing noise during wash, now no wash, only fill and drain
there is a #10 torx screw holding that cover down.do not drill it out. after you take it off you can tell if the chopper is broken.be careful for broken glass.
Oct 17, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
I have a hobart dishmachine model# CRS-66AW after filling dishmachine water will not stay in the wash tank, sometimes half of the water drains out. we have replaced the o-rings on the drain plug recently....
Which tank is loosing water?
Number 1. Make sure all curtains inside are in place.Curtains help keep the water in the proper tank. For example, curtains are missing between prewash tank and wash tank, the wash tank water could be significantly splashing into prewash tank and out the p.w. tank overflow. Are you ruling out the drain because you replaced o-rings? Look at the floor drain as machine is running. Do you see a large flow of water going down drain? There is a drain heigth adjustment on the drain lift. Mabe the drain stopper is not dropping far enough.
Mike
Mar 07, 2008 | Dishwashers
I need a service manual for a hobart crs66 dishwasher
I have one. But I don't think you can still get a manual for the older c-lines. (No "A" suffix eg. CRS-66A)
What is the problem?
Feb 27, 2008 | Dishwashers
Dishwashers Logo
158 people viewed this question
Top Dishwashers Experts
