Question about Belkin Basic Wireless Router
I switched providers so that I went from a phone-type connection to a cableTV connection. I had the Belkin router working with the phone connection and a line from my main computer into the Belkin, but with the cable connection in the other room I want it to work with only a modem connection and no computer connection. Can I do that? If so, how as it doesn't work as it is now?? Thank you. The router is a basic Belkin with Network # Belkin.3CB4
  • cslong09 Mar 12, 2011
    So, the router has no model no. on it. The disc that came with it says "Surf Wireless Router" and has a no. 8810-00202 under that and under that says F7D2301. Are you saying I need a new dsl wireless router for this installation?
    The model is F7d2301 v1. I need the wireless router to be in a separate room from the computers so that's why I don t want it hardwired to the computer as it was before. They told me at the cable company the wireless router should work just connected yo the modem and a power source.
    President:
  • 1,623 Answers
One is adsl and the other is dsl so it will only work as a router
Posted on Mar 12, 2011
  • 4 more comments
  • Martin Murray Mar 12, 2011
    you will need a dsl router to connect via wireless also are you sure the model is a belkin 3cb4 as i can find no info on it?
    please state the exact model of the router and why do you not want a computer connected to the router, what will be connected to it?
    now i have the exact model number i can help better. That router will work fine for allowing you to connect to wirelessly from your computer. you just need to plug the cable modem ethernet lead into the internet port on the wireless router. You will need to plug the wireless router into the computer to do the initial setup but once that is done you can unplug it. Do you have the software disc that came with the router. If so insert it in the pc while the router is connected and run the setup. This will allow you setup the router and setup the wireless connection
    Btw you do have a wireless card in the pc / laptop that you are using dont you? As without one you will not be able to connect wirelessly
    if you dont have the install cd you will need to download this http://tinyurl.com/65fo7b8 and run it
  • Martin Murray Mar 13, 2011
    can i ask when you said your pc was connected via a phone line, was this a dial up connection and then you fed the internet connection to the modem to share it? If so is your intention to feed the cable connection to your router and then connect the pc to the router via cable or wireless to use the internet? If that is a good explanation of what you want to do then you need to disable internet sharing on the PC. If it isnt please explain how you originally had it set up in more detail
My laptop wont log on to belkin
Sir,
Check your IP Address, Maybe its conflict with other device.
My advice to turn it automatically.
Or
Installing your Belkin router is still possible even without using its Setup CD. You can set up your router manually through the web-based setup page of the router.
Perform the steps below to set up your Belkin router through the web-based setup page.
NOTE: images may vary depending on the router model or computer you are using.
Power cycling the modem and router
Step 1:
Unplug the modem and router from the power source.
Step 2:
Connect the modem to the WAN or Internet port of the router.
Step 3:
Power ON your modem first, then your router by plugging them back to the power source.
Manually setting up your router
Step 1:
Connect the computer to one (1) of the Ethernet ports of the router.
Step 2:
Launch a web browser and enter "192.168.2.1" in the address bar.
Step 3:
Click Login.
Step 4:
Leave the Password field blank and click Submit.
Step 5:
Under Internet WAN, click Connection Type.
Step 6:
Select your Connection Type, then click Next.
NOTE: If you don't know your Connection Type, contact your Internet Service Provider (ISP). To know how to set up your router according your ISP, refer to the links below:
Cable Internet Service
PPPoE / DSL
Static IP Account
Step 7:
Enter the details provided by your ISP and click Image.
You should now be able to connect to the Internet. To verify, Internet Status on the upper right corner should read Connected.
You can also launch a web browser and go to your favorite website or try visiting the Belkin Site for more information and support on your devices.
as mention On official Belkin website vedio for Belking Online Support:
Setting up the Belkin router using an iOS device Video
Belkin
Or
In case you still need assistance then follow us for Belkin Tech Support on:Belkin Support
Mar 07, 2014 | Belkin N Wireless Modem-Router F5D8633au4A
Here what is happen my sister law had a Belkin router that went bad she got a norther Belkin router not the same one but it a Belkin here what going on she try to hook it up and she Chang to use broadband...
The ISP modem connects to the wireless routers main port. Then connect the PC to any other port on the router.
Use the default wireless settings that Belkin provides. There is a small tag under the unit with the default information. Or, use custom settings in the web admin.
Jan 09, 2013 | E-Machines eMachines Desktop PC
Need passwword for belkin wireless router
By default, Belkin routers do not have a password,just click on Submit to log in..But you should check check your Belkin router setup documents.
If you forgotten or lost router password cannot be recovered. It can only be reset by hard resetting the router.
Sep 11, 2012 | Belkin (F5D7230-4) Router (587009)
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
No internet
Have you tried testing by bypassing your router and connecting your computer directly? If you were not able to connect, then your internet service provider should be contacted.
Sep 10, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
How do I access my Belkin N Router's settings?
open internet explorer and type 192.168.2.1 and the will get u to the belkin router page and then click on mac address control and then type ur password to get in to the router and it will take u to all the mac address u have allowed or denyed
Dec 28, 2008 | Belkin (F5D72304F5D7000) Router
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
Installation CD
I lost my installation CD and received these instructions from the Belkin Tech Support, and was able to install the Wireless N Router with no problems.
Follow the steps given below for configuring the Belkin N router manually.
- Connect the computer to the "LAN" port on the router and connect the modem to the Internet/"WAN" port, using Ethernet cables.
- Take a paper clip, insert the paper clip in the reset hole of the router and hold it for 15 seconds.
- The power light will flash and then come back "ON" solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the front of the router should be lit up.
- On the computer, check if you have an IP address in the range of 192.168.2.x.
- If not, specify a static IP address, gateway and "DNS" address by following the steps given in the link-
http://web.belkin.com/support/kb/kb.asp?a=2824
- Log on to the router web interface by typing in http://192.168.2.1, in the address bar of your browser.
- By default, the password is blank.
- Click on "Connection Type" in the left hand column under "Internet WAN" heading.
If the connection type is Dynamic (cable):
- Choose "Dynamic" and then click on "Next".
- Type in your “Host Name”, if you’re Internet Service Provider has provided it. Else, leave it blank.
- Click on "Change WAN MAC Address".
- Click on the button "Clone".
- Click on "Apply Changes".
If the connection type is PPPOE (DSL):
- Choose "PPPOE" and click on "Next".
- Enter the user name and password given by your Internet Service Provider.
- Save the settings.
- Click on the "Home" link at the top of the screen.
Internet Status should show "Connected" on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information:
1. Type of connection provided by your ISP (Is it PPPOE, Dynamic or static).
2. Name of the Internet service provider (ISP).
Aug 11, 2008 | Belkin Wireless-N Wireless Router with...
Connection
Jimoli,
Wireless cards aren't compatible with all types of routers. For example, you use T-Mobile as your provider and purchase an iPhone.
Later on you decide to switch to Sprint, but find out you can't use your iPhone. Why? It's just a matter of provider compatibility AND the type of protocol they use.
Has my solution helped? Please let me know and don't forget to rate it!
Take care,
Chimpster
Jul 08, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin Basic Wireless Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
