Question about Garden
My just purchased/well used Coleman i/c 4000 generator puts out about 150 volts, no load, instead of 120v.The owners manual does not indicate how to adjust it; it says it is factory adjusted. It may have been back in 1989...
    President:
  • 3,074 Answers
Probably running too fast. You can slow it down by adjusting a screw behind or near the carburetor. Monitor the voltage while doing this. The adjustment screw will be one which moves a lever with a spring attached to it.
here is a thread on it:
http://www.perr.com/forum/viewtopic.php?p=8748
Hope this helps Tim
Posted on Mar 12, 2011
Testimonial: "Thanks. I am somewhat familiar with the adjustment process, I just wasn't sure if slowing if down would lower the voltage."
I purchased a Coleman Powermate 5000 6 years ago: Ser: 94411583. Never really used it for any length of time. Kept for emergency. An electrician checked it for voltage output a short time ago. 240V...
Voltage is adjusted by raising or lowering the engine speed (governor adjustment), however one must also pay attention to the rpm because your generator was designed to produce 120 volts at 60 cycles while turning 3600 rpm. Your electrician should have tested for htz while testing for voltage. I would recommend re-testing under load and adjust governor to turn 60 cycles to see resulting voltage.
Sep 30, 2010 | Coleman Powermate Powermate 5000W...
Where can I get owners manual?
go to powermate.com and click on the "manuals" button.
May 25, 2010 | Coleman Powermate Premium Plus 6250W...
I'm looking for an owners manual for a Coleman Powermate 4000
You may not be able to find the owners manual, but if you search using model / type #s off the engine, you may be able to find the manual for the engine from the manufacturer.
May 07, 2010 | Coleman Electrical Supplies
I'm reading 130VAC on the output. Can this be
It should read 115v-120v with full load. Yes, you can slow the engine down just a little, depending on the engine, there will be a high rpm adjustment. 130v with full speed, no load, is really not too bad.
Nov 26, 2009 | Coleman Powermate Powermate 5000W...
Coleman powermate 4000 pops circuit breaker on the 220 side.
Don't know what you mean by "on the 220 side".
The generator has two joined circuit breakers that each are 110 volts. Between the two is 220.
If just one of those is opening WITH NOTHING PLUGGED IN, then there are only a few explanations.
1. There is a short in the wiring or the wiring has been tampered with and connected incorrectely.
2. The switch that switches the mode from 120 to 240 has gone bad, possibly with a welded contact. This would occur if the switch is changed with load on the generator. This could put a driect short on half the generator winding and cause one of the breakers to blow.
3. Worst is a winding short in the generator. Fortunately this is the least likely.
4. The 220 receptacle has been broken and insulation failed shorting one terminal to another.
Nov 14, 2009 | Coleman Powermate Premium Plus 6250W...
Yamaha Generator YG 4000 Dies when load is applied.
turn the throtle knob to while checking voltage & hertz
Jun 05, 2009 | Reliable Yamaha YG4000D 4000 watts/33.0...
I plug a 1/2hp drill and use it I notice if I use anything else it is low of power. I put a meter on one plug and drill on other, and it reads upper 80-95 volts with drill running
Please check the owners manual.and see if the 6250W is surge power or steady state...it is not unusual..for this to occur...possibly the generator needs to be adjusted ( sped up slightly )..do not let the 120 volts output exceed 126 volts...
Apr 30, 2009 | Coleman Powermate Premium Plus 6250W...
I have a Honda generator model Eg1500c. It seems ok....120v 60Hz..but occasionally the motor acts as if it is under a very heavy load and the voltage goes up to 200+ volts. The brushes look good and the...
It sounds like there may be an intermittent short in the output or the stator windings. You'll need to carefully check for bad insulation between the winding and ground, I'd use a megger for this.
regards,
Carl
Feb 20, 2009 | Coleman Powermate Premium Plus 6250W...
Looking for owners manual for coleman powermate 4000
Hi
First you need to change the plug with a new one with the same heat range(too long time).Priming the engine few times(put some gas in the cilinder through the plug hole)and start the engine until it runs constantly.
bestregards savumihai71
Feb 06, 2009 | Coleman Powermate Premium Plus 6250W...
Garden Logo
89 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
