Question about VuPoint PSC500VP Digital Photo Converter
I am going to install Windows 7 on my computer and am wondering if there is a new installation driver for it. Right now what I have says good for XP and Vista (32 bit.
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Can not find a driver
There is nothing you can do to make the PS-C500-VP work with windows 7. They are not compatible. Even Microsoft confirmed it.
It is either you get a higher model of Digital Photo Converter or you use windows xp or Vista. But for windows 7, it cannot work. There is no trick whatsoever that can be done.
I hope the above information is clear.
Regards.
Posted on Jun 19, 2011
I need updated drivers for the Asus AiGuru S2 skype phone using Windows 7.
Download the XP drivers from the Asus website, they are easy to find with a quick search. Once you have them downloaded, right click the file and choose properties. Once the properties box shows up, click the compatibility tab. Check the box that says "Run this program in compatibility mode for;" then in the drop down menu chose Windows XP SP3. That should allow you to install the drivers on your XP machine. Once the software is installed you will probably have to do this again to the installed .exe file so it will execute properly in Windows 7. Good Luck!
Oct 06, 2012 | ASUS Brand New AiGuru S2 Skype Phone Vista...
I need cs330 installation driver for my windows 7... help me out pls.
The bad news: Your webcam is not supported on windows 7 their are no drivers for it.
The Good news: You can try to see if windows xp drivers will work. If not Go get a shiny new webcam!!
Jul 19, 2011 | Intel Deluxe PC Camera CS330 Webcam
I can't install the software on my new windows 7 computer how do i fix it and where i can find the driver? It says its only for windows xp
Hello!
Your camera is compatible with Microsoft Windows 98/ME, Microsoft Windows 2000 / XP.
Please, contact manufacturer to provide you update if available, and only then you can use it with Windows 7.
Also try Windows 7 forum and support.
Regards!
Jun 20, 2011 | Veo Advanced Connect Webcam
I need drivers for cannon printer BJC 85 to run on windows 7
There are no officially supported Windows 7 or Windows Vista drivers for the Canon BJC-85 printer. If you have the 64 bit version of Windows 7, then you have no choice other than to buy a new printer or use this printer in Windows XP Mode. If you have Windows 7 64 bit then please post back here with that information or create a new FixYa problem, and I will help you set up XP Mode so that you can use your printer.
If you don't know whether you have 64 bit or 32 bit Windows 7, then please follow these steps.
1. Press Win+R to open the Run command.
2. Type "MSINFO32" into the dialog box and press enter.
3. Look for item "System Type" and note whether the value is x64 or x86. (x86 means you have a 32 bit OS)
Assuming you have the 32 bit version of Windows 7:
1. Go ahead and download and install the XP drivers by following the link and clicking on "I Agree - Begin Download". Here are the drivers for Windows XP: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/bjc_series/bjc_85#DriversAndSoftware
2. Save file to the Desktop for easy access.
3. Right click on the downloaded file and select "Properties".
4. Select the Compatibility tab and check the box for "Run this program in compatibility mode for Windows XP (Service Pack 2)".
5. If the installer completes, then restart the computer and attempt to print from the Canon.
If the installer fails follow the next set of directions:
1. Make sure the printer is plugged in, turned on, and connected to the computer via USB.
2. Press Win+R to open Run command.
3. Type "DEVMGMT.MSC" and press enter.
4. Look for a device that has a yellow exclamation point next to it. If you have more than one, look for a device that says "USB Input Device" or "Unknown USB Input Device".
5. Right click on the device that has a yellow exclamation point next to it and select Properties.
6. Click the Driver tab and select Update Driver.
7. Click "Browse my computer for driver software".
8. Select "Let me pick from a list of device drivers on my computer".
9. Scroll down to "Printers" and select Next.
10. Click "Have Disk" and select "Browse"
11. Browse to "C:\Temp\bjc85Win2kXPv150" and select "bjc85.inf" and then click Open and then OK.
12. Ignore all errors that Windows gives you and install the driver, restart the computer, and attempt to print.
Good luck, post back if you have any difficulties, and thanks for using FixYa,
Apr 06, 2011 | Cannon BJC-80 Printer Driver
I've upgraded my computer n hv windows 7 n my scanner Umax Astra 5600 does not operate on the new computer. I need yr help in getting the driver for windows 7 for my Umax Astra 5600.
most old scanner are not working with windows 7 and also 64bit of win 7
VueScan is bringing them to life ;)
http://www.hamrick.com/
Feb 28, 2011 | Computers & Internet
I have just bought a new computer and i am trying to install my linksys adapter to my new computer. it worked fine on the old 1, but is not working on the new 1. I am wondering what could be some problems
The WUSB54GSC adapter had been out of production for a while...the last driver update was for Windows XP in 2008 (for Version 2 devices). You should carefully examine the device to see if it is Version 1 or Version 2, as this is necessary when visiting the driver page.
If you're trying to use the adapter on a Windows 7 machine, and Windows 7 does not automatically install the driver, then you're pretty much out of luck as Linksys does not supply a Windows 7 driver for this unit. They don't list a Vista driver, either, although often XP drivers will transfer to Vista without difficulty.
So...if you're trying to install it on a Vista machine, try downloading/installing the XP driver for your device version...it MAY work. If that does not work, or if it's a Win 7 machine, time for a new adapter.
Most new computers these days (at least laptops) have wireless built-in and don't need a USB adapter. I'm assuming, therefore, that you're using this on a desktop. If so, and you need a new one, very good quality ones can be had at WalMart for around $20. Just be sure whatever you buy is compatible to your operating system. It will be printed on the packaging.
Hope that's helpful.
Jan 20, 2011 | Linksys WUSB54GSC Compact Wireless-G USB...
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
I have moved and can't find my installment papers for my broterh MC 665cw printer is it possible to install without have this information, if so can u please tell me how to install. also, i have also...
Hi
You will have to get the right software for it to run, I will try to find it for you but this could take time because it is not easy to find a driver for Windows 7, most drivers are for windows xp, but they have made some drivers for the new windows 7 but not for all printers yet, vista driver will work as well but that’s another driver hard to get hold of also you go to make sure if your windows 7 is 32bit or 64bit you are using it got to be the right driver for it.
That’s the problem with the new windows 7 at this moment.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 01, 2010 | Brother MFC-665CW All-In-One InkJet...
I have a microtek scanner model #4900 which I gave to a good friend who has the new windows 7 operating system how do I get the driver files to enable it to work on her machine?
On the Microtek web site, I only see an XP driver. Your friend could try installing a generic TWAIN compliant scanner that is included in the Windows 7 OS or try to install the XP driver using the XP SP3 compatability mode (right click on the file, choose Properties and then the Compatability tab). Those drivers are at http://support.microtek.com/downloads/drv_specific.phtml?slct_os=8&prod=14&bymdlnme=1 .
A different method is available on Win7 Pro or Ultimate. Download and install the XP mode to create a virtual computer running Windows XP. Install the scanner to this "second" computer. Your friend will probably need to save the files to external media to transfer them between the two "computers".
I hope this helps.
Feb 01, 2010 | Microtek ScanMaker 4900 Flatbed Scanner
No vista drivers
You should download the driver for Windows XP, unzip it (if not specified otherwise C:\temp\cs330_XP).
I guess that if you say the camera doesn't work it means you already tried to connect it to the USB in your computer. If so, right-click on "My Computer" and click on "Manage". Go to "Device Manager (under "System Tools"). You should see there a device named "Unknown Device". Double click on it and go to the Driver tab. click "Update driver..." and select "Browse my computer for driver software". Now, select the location you unzipped the driver to (as said before, usually C:\temp\cs330_XP) and click next until windows will try to install the driver. This can take from a few seconds to a few minutes. After a while (for me it took about 2.5 minutes so be patient) windows should say the installation was succesful.
Enjoy :-)
Aug 28, 2007 | Intel Deluxe PC Camera CS330 Webcam
VuPoint PSC500VP Digital Photo Converter Logo
286 people viewed this question
Top VuPoint Office Equipment & Supplies Experts
Lawrence Oravetz
Are you a VuPoint Office Equipment and Supply Expert? Answer questions, earn points and help others
