Question about HP Office Equipment & Supplies
I HAVE A hpC7200 PRINTER.i HAD A PAPER JAM AND TOOK THE BACK OFF AND REMOVED THE PAPER THAT WAS STUCK. HOWEVER A CORNER OFF THE PAPER IS MISSING AND THE PRINTER STILL SHOWS A JAM AND WILL NOT COPY. THERE IS NO SIGN OF PAPER STUCK THAT I CAN SEE PLEASE ADVISE
    Novelist:
  • 137 Answers
HP has dedicated a really hard to find, diagram, to the issue as well as an HP-YouTube Video solution. If either of these aren't working for you there is one more thing to check that HP, does not mention.
Use this as a last resort, and only if you're out of warranty and you would be trashing it anyway. This may be a little difficult to understand, as I do not have a photo, but a little patience will go a long way with that model. Turn it over, look for a "Y" shaped cut-out, you'll find a gear/cam mechanism.
Posted on Mar 12, 2011
HP C6280 printer paper stuck deep inside remove cover
I suggest You Go to Official HP Printer Page For You HP Printer Problem On Below HP forum URL Link: Paper Jam Message Displays on the All in One In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : HP Printer Support
Feb 27, 2014 | Office Equipment & Supplies
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
Printer pulls paper in from one corner
this problem occurs only when one side of the paper spooler is jammed and stuck. the spooler pulls the paper causing the paper to rotate inside the printer and getting stuck.
take professional help in clearing the jam and freeing up the spooler.
Mar 15, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Epson NX415 Paper jam. I took paper out but it's
Check for other bits of ripped off paper stuck in your machine.
Try turning off your printer for 30 secs and turn it back on.
Mar 11, 2010 | Epson NX415 All-In-One Printer
The paper jam button is on, but there doens't seem to be any paper in there. I took the paper tray out and examined the underside of the printer, no visible paper jammed. I undid the back access part,...
power off printer
remove paper tray
open front panel
remove both tonor and phto conductor kit (tonor seats inside of that)
inspect inside the printer
Chances are there is a fragment of paper in the right corner near the paper sensor
replace components
restart printer
Keep me posted
Feb 01, 2010 | Lexmark E232 Laser Printer
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
How can i remove the paper inside the printer
For the paper jam issue turn around the printer and open the back door to pull the paper.
and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My HP PSC 2355 tells me there is a paper jam
Request you to get it check with the engineer personally or their might be a piece of paper stucked somewhere in the corner. I tried the same and was fixed
Jul 02, 2009 | HP PSC 2355 All-In-One InkJet Printer
My MX310 got a paper jam and when i pulled the paper out a small piece of the corner tore off and is still stuck in the printer. The printer now continues to claim there is a paper jam but i cant visually...
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the Rear Tray or from the Paper Output Slot, whichever is easier.
If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
Jun 05, 2009 | Canon MX310 Office All-In-One Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
Seeker5211
Seeker5211
