Question about Dell Inkjet 720 Printer
I have a dell computer and a dell printer and no software. i cannot install the printer cause the installation wizard doesnt recognize it.
  • 746 Answers
Hi, here is the link where you can choose your exact model and download your software or driver free.
http://search.dell.com/results.aspx?s=bsd&c=us&l=en&cs=04&k=Dell+Inkjet+720+&cat=sup&x=7&y=5
Contact me for further more information and rate my answer.
Best of Luck
Posted on Mar 12, 2011
Brother hl-5280dw printer just stopped printing. pc says doc failed to print - printer error or busy. test pages work directly from printer but printer does not recognize that documents are being sent to...
hi try re installing the software of the printer .completely uninstall first the previous software of your printer then install it again.to begin with the installation do no connect first the printer usb cable run first the CD the follow the wizard instruction installation.wait till the wizard prompt you to connect the printer and power it on.in this process the computer will automatically search your printer.then click next.until installation is successful.
you can also replace your USB connector for your printer if the computer cannot detect your printer..
good luck!
Jul 08, 2011 | Brother HL-5280DW Laser Printer
"No Printer Found"
This sounds like your OS is not recognizing plug and play devices. You can try to do manual install from a CD or Manufacturers site.Just go to control panel and printers and click add printer and click add local printer and just follow the prompts. Make sure printer is unpluged from the pc before installation wizard tells you to plug it in since some will not install if plugged before driver or software installation. Hope this helps.
Mar 04, 2010 | Dell 1110 Laser Printer
How do i install a Kodak esp series 3 printer to a dell computer
Take the CD-ROM that came with the printer, and install the software.
When prompted, connect the printer to your computer.
If you have lost the CD-ROM disk, you can download the software from Kodak's web-site.
Oct 29, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Dell printer deletes off of dell computer
if it deleted it ..this only mean that it was something wrong with the driver ...( a bug or so ) or ...it just didnt recognized it ...and it still exist but you dont found it ..cause its a plane driver and dont came like a program ...so in this case on reattaching the device ...just run the add new hardware wizard ...let it find new attached devisez but not installed yet ...and after that let it install the thing automatically ....
Sep 10, 2009 | Computers & Internet
My computer is old and it doesn't recognize the camera. I plug the camera in and i get a box that says this wizard searches for new drivers for: samsung digital camera i click continue and i cant find...
if the pc ...doesnt find the software ..you need to reinstall the software ...or run it manually ...so ...plug the camera ...insert the software ...and run the add new hardware wizzard ...when will prompt ya ...choose manually install and point the wizard ( browse ) to the disk drive ....it will find the software it needs and it will install i t...
Sep 08, 2009 | Samsung SL30 Digital Camera
1700 printer
How did you install the printer?
I have found that if you just let your computer recognise new hardware, it really has a hard time with the USB printing to the 1700's.
Originally there was a disk that came with the 1700 printer. You do want to use that.
During the install, you run the software, and then turn on the printer. (You can have the printer on during the install, but ignore the Windows Wizards that come up).
If you don't have the original 1700 install disk, you can download it from Dell.
The problem is with USB port configuration. These little 1700's are just a pain sometimes if not installed the way they were originally designed.
Jul 31, 2008 | Dell 1700n Laser Printer
I am trying to load hp psc 2175 all in one into the dell computer we have and i take it the computer doesnt recognize the hardware how can i get it to recognize this piece of equipment for i have loaded...
The major problem occurs ?????? You keep on trying installing but it will not succeed????????.
The solution change your usb cable and buy one good quality cable specified as USB 2.0 standard I hope your problem will be solved
Remember one thing never install the software while your printer is connect and live - disconnect it and install from the cd because hp installation is programmed accordingly that you have to install the driver first and it will ask to make it live and it automatically detect and register the port in your system.
Thanks from Hothawk
Jul 19, 2008 | HP Computers & Internet
Trouble with installing software for PCI FLASH Memory Dell All-in-one
First uninstall the Lexmark and unplug it from your system. Next, do a SHUT DOWN. Turn on your system, load the CD, go through the installation process, then plug in your Lexmark.
Jul 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Put the cd in the computer, and see if there is a setup.exe file, or something of the sort on the CD itself.
Also, you can download the drivers from dells website. Your install cd may be bad. Your computer may also need to be updated, sometimes you need to log into http://www.update.microsoft.com/
and there may be drivers for it there on the bottom of a custom update.
If you tell the wizard to find the drivers automatically, it sometimes only looks for it on the hard drive of your pc. Tell it to install the drivers from a specific location, then select "from a removable medium". You can also try installing it from a specific location, click browse, and try to find the location of the drivers on the Dell installation cd.
Jan 15, 2008 | Dell 924 All-in-One InkJet Printer
Dell All-In-One 810 Printer installation problems
From what you describe the printer is not installed correctly. I would try uninstalling everything associated with this device, unplugging it and then retry the installation process again. I don't know if the instructions are clear but you should not connect the USB cable to the printer until after the software is installed or when prompted by the software wizard.
Jan 01, 2007 | Dell 810 All-In-One InkJet Printer
Dell Inkjet 720 Printer Logo
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
