Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door opener will run a second forward then a second in reserve. what do I do to fix it?
    President:
  • 3,197 Answers
Check the door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little.
Posted on Mar 14, 2011
Starts with the remote but shuts off when a door is opened
Garage Door Opener Troubleshooting step by step - YouTube
? 3:41
https://www.youtube.com/watch?v=b8w2w5ZAc1I
Feb 5, 2014 - Uploaded by Andrew Hill
How to Fix A Garage Door Opener - the opener shown is the Craftsman 1/2 HP ... First start with the obvious and easy to check problems. ... opener button on the wall will open the garage door but not your remote or keypad, ...
Auto Start Engine Shuts Off When open door -
The Top 10 Reasons Your Garage Door Won't Work
customoverheaddoors.net/reasons-your-garage-door-wont-work/
Jun 5, 2014 - To help you troubleshoot your garage door issues, here are the top 10 ...Garage Door Closes Part Way, Then Opens Again ... Automatic Garage Door Opener Runs for a Few Seconds then Turns Off but Door Doesn't Move
Jan 05, 2016 | Building Materials
Garage door opener
Does the travel direction make a difference? There is typically upward / downward force adjustments. Also when it stops will it start again immediately if you activate it.
Mar 31, 2017 | Building Materials
Sears Craftsman 1/3HP garage door opener problem
If motor continues to run but no chain action check for missing chain tooth or cam gear worn.
Sep 22, 2017 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener that wont work and the main opener in the garage keeps blinking how can i fix this?
If by "main opener" you mean the wall control is blinking, press and hold the lock button for 3 seconds.
Oct 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door opener 1/2 hp will not open door
It sounds like your chain is out of sync with the limit switches. Loosen the chain enough so that you can remove it from the sprocket on top of the motor unit. Now run the opener until the sprocket runs counterclockwise and stops. Now with everything attached and the door in the open position replace and tighten the chain. You are now in sync. You may need to tweak the up and down limit controls which are on the side of the motor unit.
Aug 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener (Unit run front & back only for 2 second)
Double check to make sure the sensors are wired correctly. The 2 solid white wires go to terminal 2 and the wires with black stripes go to terminal 3. If the wiring is correct then you possibly have a bad RPM sensor. The RPM sensor is a small circuit board just in front of the motor.
Jul 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener (chain) motor runs in reverse. Trolley slides forward trying to close door, even though it is closed, instead of sliding toward motor to open door. Happened out of the blue - was
Loosen the chain enough that you can remove it from the sprocket. Run the opener until the sprocket turns counterclockwise and stops. With the door in the open position replace the chain. You will probably need to adjust your open and close limits per your owners manual.
May 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote will not operate garage door opener from outside garage
Will the remotes work in the garage? If yes but not outside with the door closed you might have radio interferace with your remotes. You might have to chage to a your reciever and remotes to a different brand (frequency). Sometimes it is less trouble to change out the operator. Chamerlain changed frequency from 390 (old) to 315 (new).
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Dec 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener doesnt close all the way.
The motor is probably either stalling because the door is too stiff, or you have a beam break detector that is being triggered when the door is halfway down.
Nov 23, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
24 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
