Question about Husqvarna Garden
I have just changed the chain on my Husqvarna 440e but left the brake on. Now I have run the chainsaw the brake sems to be stuck on. Can anyone help (stupid mistake , should have read the instrcution manual 1st) !!
  • Husqvarna Master
  • 2,239 Answers
Do not run the saw any more, remove the fixing nut and take the side cover off, you may well have done some damage now,if the brake was activated prior to you re fitting it, the band would have been smaller than the drum, this will now have forced the band into the drum seizing the two together, check the condition of the brake band,and sprocket, any sign of damage and it will have to be replaced.
You need to load the brake before re fitting, clamp the cover in a vice , be carefull not to damage the cover, either remove the hand guard from the machine and use this as a tool too fit into the brake quadrant and re load, or find a suitable u spanner that will engage into the quadrant to load the brake, you will need a fair amount of pressure to compress the internal spring, and load the brake.
Good luck
Posted on Mar 12, 2011
Model 137. How do I assemble the brake spring?
Husqvarna Chain Brake - YouTube
? 7:13
https://www.youtube.com/watch?v=gK7eKakMCz8
Feb 13, 2011 - Uploaded by thoughtfulace
... brake assembly and install the spring in the cover of ahusqvarna saw. ... Next time I will try to remember to disengage the brake first. .... How to Remove a Chainsaw Clutch Cover and Reset the Chain ... Restricted Mode: Off.
husqvarna chain brake is stuck. easy fix - YouTube
? 6:31
https://www.youtube.com/watch?v=usP5XaXO7-8
Dec 19, 2012 - Uploaded by Plotnikoff Nate
How to fix your chain brake from being stuck locked to unlocked the easy way. ... BTW, I will NEVER sharpen a chainsaw again. This new chain ...
How to assemble the brake spring on a 137 husqvarna ...
www.fixya.com/.../t26010777-assemble_brake_spring_137_husqvarna
Dec 16, 2015 | Husqvarna Garden
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
Husqvarna chain drive stoppped - appears to be frozen sproket
mine meted the chain brake and applied the brake on me also check the chain could be to tight
Jun 27, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Describe your "Chain Saw -
A couple of things too check here, remove the air filter and clean, remove the spark arrester gauze in the top of the muffler, it is held with a single screw, once the screw is out pull the tab to the side and out, this gauze should be clear and not full of carbon, clen or leave out.
Aug 21, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Does the husq 440e have an oil adjustment on it?
Hi mwaltz48,
Yes, Huskys have a screw adjustment on the bottom, under the chain sprocket assembly.
While looking at the bar side of the saw, turn it over and you'll see a screw that has 3 positions.
Turn the screw to the right will decrease the oil flow, left to increase it. If you put a longer blade on, you should increase the oil flow.
A way to check your oil flow is to run the saw with the blade pointing at something light, such as a freshly cut chunk of wood, or the end of a log, etc. You should see a light line of oil appear.
I hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 08, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna chainsaw 235e starts but the chain won't move. Maybe the brake is stuck??
Does the brake seem to 'snap-over' like it should? Pull it back to release position, and remove the drive cover. Check the entire brake for debris accumulation or bent/damaged brake band. Check the chain to see if it is being oiled. Remove the bar/chain and clean the entire assembly, particularly the small oil passages in the drive end of the bar. Start the engine and watch for oil oozing out of the small side port where the bar fits. If ok, reassemble the bar/chain. If no oil comes out, investigate the oil pump, lines, and filter/valve in the oil tank. Mount the side cover, but leave the fasteners finger tight. (The chain teeth cut toward you on the bottom run) Tighten the chain until the lower run comes up to the bar, but can still be turned by hand. Tighten the fasteners and recheck the tension. Trip the chain brake and make sure it locks the chain, then release it and make sure it turns freely. Check the chain oiling by running the bar tip at speed near some cardboard--it should leave a thin line of oil on the board. Hope this helps!
Jun 26, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Chain will not move freely. When hitting gas will
Did anyone explain how a chain brake works?
Pull the forward most handle as far aft as possible. It should click if it was tripped. Wearing gloves can you easily rotate the chain?
Remove the clutch cover. If it seems stuck the chain brake is tripped do not force it off, reset the brake. Inspect all interior parts for small twigs or pieces of tree that have jammed the brake or clutch. Anything beyond this please see the dealer that sold it to you. HTH
Lou
Oct 24, 2009 | Husqvarna Garden
Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Where can I purchase a wrench to adjust the carburator on a 440e chain saw?
Purchase at any hardware or home improvement store (ACE, True Value, Lowe's Home Depot etc)
Jul 06, 2009 | Husqvarna Garden
Garden Logo
150 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
