Question about Brother MFC 420CN All-In-One InkJet Printer
Won't turn on
Can the mother board be broken? Machine won't turn on.
  • 1 more comment
  • Anonymous Aug 01, 2008
    no leds no power??
  • Newbee01 Aug 11, 2008
    I have the same problem, my led screen went and then when I unplugged it and plugged it back in the power just won't come on tried different outlets but with no success! Any assistance would be greatly appreciated.
  • georgie6011 Apr 13, 2009
    doesn't work!! mine won't turn on wither, for no reason!!! i just bought it!!
Had the same problem with my 420 CN. The only way I got it to work again was to unplug from power bar and plug directly into wall. Machine powered 4 seconds after I plugged it in. I hope it works for you too.
Posted on Jan 11, 2009
La cimbali m1 machine won't heat up
No heat can mean one or more problems. A few checks can help keep your service expense down. Check power to machine; breaker tripped? Is it plugged in COMPLETELY? Digital displays also have programmable on/off times (some include the days of the week). Time and day/date set correctly? Multi turn selector switch broken or loose? Tank filled properly? (Site glass showing water at correct levels?). A qualified technician can check the heater overheat thermostat (or thermal fuse). Broken heater elements or wires. Pressure gauge. Tank overflow safety switch. And finally blown digital power switch, coil contactors, power board, and main PC Mother board. There may be other problems but these are the most often occurring in order of severity (and expence)
Jan 11, 2014 | Coffee Makers & Espresso Machines
Power on a hp mother board
As a student of electronics, you would be a better judge of the worth of the Laptop Parts in YOUR hands. As a project in what you can make work from parts , why not. As a workable, useful machine , doubtful. Ask yourself, Is it a project, and you have access to Misc. computer parts that will fit this or do I have to invest Time and Money , and end up with nothing but a jumble of broken computer parts. Do your self a favor, List the working Spare Parts on Ebay, make a few bucks and 1, Have a few beers, 2, Save the money towards buying a good used computer.
Dec 26, 2012 | HP Pavilion dv6000z PC Notebook
Viking 400, will turn on but will not sew
if the machine will turn on but not sew then the machine needs to be
serviced to find out why it won't sew.
Apr 17, 2012 | Husqvarna Sewing Machines
My toshiba PSAgou laptop won't turn on
That is a common problem with the Toshiba. The center pin tends to get broken off. I have had to repair them by either installing a new mother board, or removing the mother boars and soldering in a new power port.
Feb 28, 2012 | Toshiba Satellite PSAG0U-02D00M Notebook
My computer won't turn on.It's a CompaqSR1820nx
Hi.
Check if the power supply its working use a multimeter. If it is check all the wires. If you see there's no problem with them maybe the mother board got broken. You can replace it, it's such an easy job.
Aug 28, 2011 | HP Compaq Presario SR1820NX (ER919AA) PC...
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I cant turn it on
If you have just installed a new mother board, refer to your manual and double check your connections for pwr switch. If this is a machine you've had for a while and it just stopped powering up then your power supply is probably broken.
Jul 07, 2010 | Gigabyte Motherboard Socket775 -...
Mother Board
Laura,
You win. Most GE side by side refrigerators have an electronic mother board.
Data is feed to it from 5 thermistors, 2 in the freezer and 3 in the fresh food compartment.
In turn the motherboard takes that varying information from the thermistors and controls all functions in the machine.
Apr 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Brother MFC 420CN All-In-One InkJet Printer Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
