Question about Canon PIXMA MP150 All-In-One InkJet Printer
My printer setup disk no is it compatible with window 7 64 bits
  • Canon Master
  • 670 Answers
Take this link to Canon, select your operating system from the pull down list and select your needed drivers and desired software.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp150#DriversAndSoftware
Posted on Mar 12, 2011
Is there any possibility of making this printer compatible with windows 7
With Windows 7, I found that installing the Vista software/drivers in the compatibility mode works well.
Right click on the setup.exe file, left click properties, left click compatibility. Change the compatibility to Vista(Try Vista SP2). Then install the proper drivers. You'll be prompted when to connect the printer(powered on).
***To install drivers, sometimes the file unzips and does nothing. You have to look for the setup.exe file, right click on it, then left click run as administrator***
As for scanning, if you have the disk that came with the printer, then insert the Printer disk and stop it from running. Go to My Computer and double click on it. Look for the drive with the Dell disk in it. Right click on it, left click explore. Look for the OCR Folder. In the OCR Folder, there is an Abbyy Folder. right click on setup.exe, that's in the Abbyy Folder and left click run as administrator. This will install the OCR program.
Scanning
Scanning using USB connection, open the Dell All-In-One Center, click on scanning and copying and scan from there.
Scanning wirelessly, use the scan buttons on the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 01, 2011 | Dell A940 All-In-One InkJet Printer
MY SCANER IS NOT WORKING
Try running Delete Print Jobs to remove any stuck print jobs in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download the proper drivers. If using Windows 7 32-bit use the Vista 32-bit and if using Windows 7 64-bit use the Vista 64-bit drivers. Install the drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block communications.
Links to the patch(drivers can be found at...
Dell 926 Photo All-In-One Printer owners thread (W7)
Or
Try Simple OCR
Rick
May 08, 2011 | Dell 926 All-In-One InkJet Printer
Can I get windows 7 drivers for my DPP FP30? Just changed to W7 and it looks like my precious printer won't work any more!!
Install the drivers in XP or Vista compatibility mode.
Insert the setup disk in your CD/DVD drive. Choose to view the files in Explorer.
Scroll down to the file "Setup," which is identified as an application.
Right-click the file and select "Properties." Click the "Compatibility" tab at the top of the resulting window.
Check off "Run this program in compatibility mode for:" and choose "Windows Vista" or "Windows XP Service Pack 3" from the pop-up menu.
ALSO check "Run this program as administrator" at the bottom of the window.
Press "Apply," then "OK."
Now you can double-click the "Setup" file and run the software installer.
Mar 12, 2011 | Sony DPP-FP30 Thermal Photo Printer
I have a Veratec desktop computer and am having all kinds of problems with it. It is one year old. Will not communicate with my dell printer A920 and is difficult to operate otherwise. Please help.
Well what operating system do you have on it? Windows7 doesnt like some printers. check online for print drivers and update them. Follow this link to help you with that... http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_FA36C542525D975EE030030ABD621881&isLegacy=true
you can also try this approach... First, let's make sure your computer has the latest Windows Updates, especially .net framework, needed to run many applications and the latest Java.
Disconnect your printer.
Download and run this patch (***WARNING*** The patch for this printer also removes other Dell applications, like Dell Dock, Dell QuickSet and other Dell applications)(These applications can be downloaded at Drivers & Downloads and can be reinstalled) to completely remove the printer from your computer. Run the patch(A MUST on Vista Machines) until it prompts you to restart your computer.
If using Windows 7 also try...Manual Printer Driver Removal
XP Drivers
Vista 32-bit Drivers
All other drivers
Install the proper drivers. You'll be prompted when to connect your printer(powered on)
If using Windows 7, use the Vista drivers in the compatibility mode.
Scanning
Mar 04, 2011 | Computers & Internet
I have a Dell 944 all-in-one printer and just got a new Toshiba laptop. The new laptop uses Windows 7, which is not supported by the printer. Is there an update to the drivers & utilities to make...
Did you try the Vista drivers in the compatibility mode. Drivers and instructions can be found at...
http://en.community.dell.com/support-forums/peripherals/f/3528/t/19306932.aspx
Let me know what happens.
Dec 09, 2010 | Dell 944 All-In-One InkJet Printer
Have no disk to installlexmark x6170 printer
Here is the link to the Lexmark website to download the drivers. http://bit.ly/b0XDka . If your computer is Vista or Windows 7, check if it's running on 32-bit or 64-bit operating system by clicking on the Windows logo Start menu > right click on Computer > Properties. By the way, for Windows 7, use the Vista driver. It is compatible with it. Printer is not compatible with Macintosh.
Apr 19, 2010 | Lexmark X6170 All-In-One InkJet Printer
Intel CS331 web cam not compatible with Windows 7
THAT SOLUTION DOES NOT WORK!
ANYONE HAVE ANOTHER SOLUTION?!
Apr 10, 2010 | Intel CS331 Webcam
Install
This solution is not for the XBOX version of the game, this is only for the PC version of the game Bard's Tale.
You can still try to make the game compatible for installing it on the Windows XP 64 bit by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
The same set of Compatibility steps can be used for installation of older games installation on Windows XP 64 bit and Windows Vista.
Again, this solution is not for the XBOX version of the game.
Sep 06, 2008 | Vivendi Universal Bards Tale: Song of the...
Samsung ml-1740 printer - their driver not compatible with my Windows Vista
Try to install the software by clicking the right button of mouse on it and chose 'run as administrator ' from drop down menu.
Before installing do the following:
Unplug pinter USB.
Remove printer from installed printers (delete ) from Windows control panel.
Keep printer usb cable unplugged when you start driver setup software, you will be asked by setup wizard when to plug in the cable, or reconnect after installation.
If it still does not work, do a system restore to a date before you plugged in the printer for the first time, then repeate software setup as above.
If it still does not go you may need to reinstall Vista or replace the printer, one of the system files or regisries entries had developed a problem with printer driver, and is not easy to locate and remove the files concerned one by one.
Regards
Sep 01, 2008 | Samsung ML1740 Laser Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
27 people viewed this question
old marine
old marine
