Question about Samsung DualView TL220 Digital Camera
My Samsung TL225 froze and it won't turn on anymore. I have tried charging it but nothing and since it froze while it was on, the lens are sticking out.
5 Suggested Answers
  • 11967 Answers
SOURCE: cannot open the lens anymore
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 04, 2010
SOURCE: Samsung tl225 lens is stuck out and won't retract,
I had this very same problem, and I managed to fix it. In my case, this happened because a gear inside the lens housing was knocked loose. To gain access to it, you'll have to disassemble the camera and remove the lens assembly(the black cylinder that takes up half the camera). Unscrew everything, being careful not to damage any of the fragile ribbon cables. When you finally open it, the gear you are verifying is a tiny white gear that is under a small, silvery cylinder. This is the same silvery cylinder that sits aside the entire lens assembly. Make sure it is firmly locking teeth with the nearby black gear. If it isn't, carefully jiggle it while pushing it down, and it will lock teeth with it. Also, be careful to note where the spring is, as it must be present for the camera to work.
Best of Luck,
Thomas Skubicki
Posted on Aug 30, 2010
Obertelli
  • 3006 Answers
SOURCE: My mom dropped her camera
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact Samsung in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
Posted on Sep 23, 2010
  • 11967 Answers
SOURCE: my samsung tl225 camera lens
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Posted on Sep 24, 2011
Lens jamed out
I fixed a pentax with the same problem by removing the battery straight after power up when the lens motor has just tried to push the lens right out to its fullest extent. Then after making sure the lens is not crooked smack the back of the camera firmly onto the palm of your hand. Then put the battery back in. This process may need to be repeated up to 10 times or untill you get bored with it and your palm starts to hurt!
Jun 02, 2012 | Samsung DualView TL225 / ST550 Digital...
My samsung tl225 camera lens is stuck open. I have tried turning it off and it won't turn off. I have tried taking out the battery and putting it back in and still nothing happens. The camera was not...
Sep 24, 2011 | Samsung DualView TL225 / ST550 Digital...
My olympus camera (FE- 330) froze when i tried to deleted photo and the the camera froze and the screen is now black and the lens are sticking out
Try inserting a fully charged battery.
If that doesn't work; you may need a new battery.
Write back if none of these work.
Dec 29, 2010 | Olympus FE-330 Digital Camera
Samsung L73
I now also have that problem- my L73 seems to have frozen with the lens open and wont do anything, i cant even turn it off - no idea what to do!! have tried charging it, but nothings happening anymore!
Can anyone advise me what to do?
Thanks
Apr 02, 2008 | Samsung Cameras
Freeze
Congratulations on the purchase of your T9 ! The T9 has won many reviews, and rated very high for value for $'s. Now, depending on how long this unit has been sitting since it's manufacture, all new units usually require a 'wake-up'. The initial wakeup charging is critical to the battery's life, so follow instructions carefully, re charging. Then, "re-set" the T9 (ie hold both 'Menu' & 'A-B' buttons together, for 3 secs to re-initialise the built-in firmware). This procedure will overide everything. If this gets it goin, then download the latest firmware update from Samsung website (download centre/mp3) and save newest firmware onto your T9 - your manual should explain how to do this. Always update your T9 with latest firmware when available (appropriate with your Windows OS), to eliminate any bugs in the firmware. If this doesn't resolve, then use the factory warranty to have it serviced by an approved Samsung agent. Good luck.
Jul 01, 2007 | Samsung Yepp YP-T9 Digital Media Player
Samsung DualView TL220 Digital Camera Logo
268 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
