My Hp Pavilion dv2700 has a display error, it boots and then it starts to flicker, freeze and then again unfreezes. and sometimes it even goes blank. this is the third HP laptop i have seen with so much errors....its 1.5 years old...i took it to a repair shop and they just told me to get a new board, i'm kinda broke and wish there was something in-expensive i can do to repair it...i can kind of manage taking it apart and following instructions, hope you can help here...thanks
    Problem Solver:
  • 5 Answers
Sometimes with HP laptops I have seen issues with the ribbon cable that connects the screen to the motherboard. It is quite a project to get to the connector but it is best described as a compression fit connector that the ribbon cable slides into.
The other issue with this model is cooling for the video card. Being compact and crammed in the laptop case the cooling fan may be clogged causing it to overheat. Check to make sure all cooling ports are clear.
The last item if it has been overheating could lead to a motherboard or video board replacement. If the unit has been overheating for some time it will cause the components to fail.
Posted on Mar 13, 2011
Hp pavillion dv2700 is not starting, 3 beeps, 1 long and 2 short
That is some sort of video failure. "Unable to initialize video (to display the post code)"
Dec 31, 2013 | HP Pavilion dv2000t Notebook
Reset button hp pavilion
HP Pavilion not available reset button.
A hard or forced reset erases all information in the computer's memory which may restore functionality. Resetting your computer forces the system to clear and reestablish the software connections between the BIOS and the hardware.
Performing a hard or forced reset might fix the following conditions:-
Windows stops responding.
Computer stops before Windows loads - no boot, blinking cursor on a black display, and errors relating to OS not found or a missing drive.
Display suddenly goes blank and stays blank.
Software freezes.
Keyboard stops responding.
The computer does not return from sleep or suspend mode.
Thanks..
Sep 09, 2013 | Computers & Internet
Blank Screen on start. No display
You need to replace the motherboard. When nothing comes on the display this means the bios on the motherboard is bad and the board and cpu need replaced.
Mar 17, 2010 | HP Pavilion dv2000t Notebook
Blank Screen - hard drives work and keyboard lights up
Try holding F11 while booting, sometimes this triggers the recovery partition.
Sep 21, 2009 | Compaq Laptop Keyboard for HP Pavilion...
Dv2700 when starting laptop only goes first screen
If it will boot from the windows disc, install the disc and boot from cd. When windows loads, go through the start repair or recover.
Aug 30, 2009 | HP Pavilion dv2915nr Notebook
My Hp dv4000 freezes when i turn it on although power is on
Had the same problem... push on the bottom left hand corner of the computer and see if that makes it unfreeze if so... you have a bad coldsolder issue on the MOBO.. get it replaced or serviced... its a PITA (pain in the ***)
Jun 14, 2009 | HP Pavilion dv4000 Notebook
Freezing or shutoff on boot, setup or minutes into operation
Try this:
Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
May 17, 2008 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
