Question about Sony Audio Players & Recorders
The earpiece has come adrift. how do i get the inside plate of so i can reattach by replacing the screw?
  • john_mcwha Mar 12, 2011
    sony MDR-NC40
  • 643 Answers
Need to know what type headphones you have.... do you have a model number?
Posted on Mar 12, 2011
  • Tre Elkins Mar 12, 2011
    ok now, its just a snap process kinda like a cell phone back but you need to be cautious not to break the unit
Motorola w845 quantico disassembly
I have never done a w845 quantico but have done several V860 barrage phones in my time. Both of these phones have a similar design. On the barrage if you flip the screen open, on the inside of the flip there are 6 screws, undo those screws and place where you will not loose, then the top part will separate with just a little nudging (front cover from back) the earpiece in the barrage is in a small compartment and has two contacts (no screws just some adhesive) remove and replace, clip the front back together and replace screws. Most important part is to make sure you do not damage the LCD cable in the hinges of the phone.
Dec 22, 2012 | Motorola Mobility W845 Quantico
Replacing base plate
The base plate for your saw is held in place by a screw that goes through a plate that fits into the raised part of the baseplate with the elongated holes. The nut that holds the screw in place is sandwiched in the base of the two housing halves. The raised part of the base plate and elongated holes are what allow you to tilt the base plate.
Jun 16, 2012 | Saws
How to reattach the inside rear view mirror the whole attachment??
remove, little plate with correct size allen wrench. Next, buy rear view mirror glue kit, at any automotive store, and follow directions. re-attach mirror to plate, once dried on windshield, and re-tighten allen screw.
May 11, 2012 | 2006 Toyota Corolla
The retractable cord is stuck so I can't get it out to use it.
(I had the same problem) If you have the model I have, take a small screwdriver and remove screw located in center of bottom plate....remove plate and unwrap cord...reattach bottom and replace screw. I just leave the cord fully extended.
Sep 23, 2011 | Hamilton Beach 80333 Grinder
I need to replace a sensor kit on a whirlpool dryer model len2000pwo. should i go in from the back of the dryer or front/top!!! The part was in the dryer drum when i found it so im not sure the best...
Disconnect the power source to your dryer before you begin to open its cabinet. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Opening the cabinet for newer Whirlpool brand models starts at the control panel. Begin by removing the end caps found at either end of the console. Lift them from the back, and then pull them towards you. There will be two screws holding the console in place. Remove the screws, and then slide the console towards you and flip it up. You will find an additional three screws at the back of the cabinet top. Remove these and slide the cabinet top towards you and lift it off the unit.
Proceed by removing the kick-plate. There are two spring catches that need to be disengaged before you can remove the kick-plate. Each spring catch is found about four inches in from each side. Use a putty knife or some other thin and flat object to wedge in between the front panel and the kick-plate. Push down on the clips with the putty knife to disengage.
Open the dryer door and remove the screws that are holding the hinges to the door. Tilt the door up and pull on it gently to remove it. Continue the dismantling process by removing all the screws you find that are holding the front panel to the unit. There will be door switch screws, ground wire screws, and other screws holding the front panel to the bulkhead.
Reassembling the entire unit is basically the disassemble process in reverse. Replace the front panel of your dryer. Replace the dryer door, and then replace the kick-plate. Reattach the cabinet top and then push the control panel back in place and reattach the two end caps.
Dec 01, 2010 | Dryers
Seperate rearview mirror from plate both came off
f
Replacing the rear view mirror on a Ford Explorer is easy. The only obstacle you might encounter is fear of breaking the glued metal plate off the windshield. Do not sweat it. You can buy glues at the auto parts store to reattach the mirror to the windshield (Difficulty: Moderately Easy).
Instructions:
  1. Tap gently at the base of the mirror where it slides on over the metal plate glued to the windshield and pull upward. Some rear view mirrors have a small Allen screw that tightens the base of the rear view mirror to the metal plate. Disconnect the electrical plugs if your rear view mirror has them.
  2. Pull the rear view mirror clear of the metal plate. Clean around the metal plate glued to the windshield. If the metal plate has come off because of harsh weather or from hammering too hard at it, reattach it with glue designed for this job.
  3. Clean the area where you will be attaching the metal plate on the windshield. Apply the glue evenly on the surface of the metal plate that will go against the window. Be sure to clean and scrape off all the old glue before applying the new glue. Gently push the metal plate against the windshield in the spot you wanted it and hold tight for five minutes.
  4. Wait a day before putting the base of the mirror or replacement rear view mirror onto the metal plate. Do not force the base over the plate. Forcing it will likely dislodge it again. Press firmly until it will not slide along the grooves of the metal plate. Reconnect your electrical plugs and tighten the Allen screw if your new mirror has one. Adjust the mirror according to your safe viewing preference
Hope help with this (remember rated this help). Good luck.
Mar 12, 2010 | 1999 Ford Explorer
I have a 37 inch olevia hd tv..It was mounted on the wall but now we want to put it back on the base and cannot find the screws to reattach the base to the tv. Can you tell me the size of the screws?
This is a difficult one as you have about 50sizes possible for this one. Try calling olevia and giving them the model # they might have that info but its pretty technical and more then likely you'll need to go to a Home depot and just pick up several fine threaded screws (about $.05-$.10each) and try em all to see which one fits. Its a pain but may be the only way. Make sure you don't get them too long as this will damage the threads or not tighten the mount. Try about 1" to 1-1/2" screws. depending on how thick the base plate is. you want about 3/4" of the screw inside the tv depending on how deep the threads (can stick a toothpick inside it to gauge how deep) so ad 3/4" to the thickness of the base plate.
Sep 12, 2009 | Televison & Video
Cabin filter
1 Tools needed are a Phillips screwdriver and a socket wrench. Open door to passenger side of vehicle. 2 Under the glove compartment is a kick plate cover held in place by four screws. Remove the screws and take off cover. 3 The door to the cabin filter is now visible. Remove screw in door and unhinge. 4 Remove the first filter by pulling straight down. Remove the second filter by sliding forward and pulling down. Replace with clean cabin filters. Reattach door and kick plate cover.
Good luck and hope this helps.
Jun 26, 2009 | 2004 Toyota Avalon
Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
Jan 01, 2009 | Frigidaire Dryers
261 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
