Question about Whirlpool WED5300S Electric Dryer
Cant figure out how belt tensioner pully goes on thanks
    President:
  • 3,074 Answers
Http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Posted on Mar 13, 2011
My alternator belt came off and cant figure out how to put back on i got it on all the pullys but theres still alot of slack
Sounds like it's not on the idler gear. Look for a diagram of the belt routing on a sticker under the hood. Basically the smooth side of the belt goes on the smooth pulleys and the grooved side of the belt goes on the grooved pulleys.
Oct 29, 2010 | 1994 Chrysler LeBaron
Want to fit fan belt cant find the proper way
You have to find the tension pully. using a 3/8 socket wrench. not the socke but the actual wrench. place the square end of the wrench into the notch on the pully and either push or pull (depends on the v-belt system) and it should move. place your v-belt around the pully's according to the diagram under your hood leaving your tension pully to be the last one the belt goes on. Move that tension pully as mentioned above and place it the belt on the pully. The diagram under the hood should also show you where that tension pully is located.
Oct 04, 2010 | Ford Fusion Cars & Trucks
The belt for the dryer is not in place and the dryer is not longer spinning. how would i fix that? There is also a piece with a wheel on it that i cannot figure out where it goes but looks as though it is...
Look up "Tension Pully & Belt Diagram" on internet for your dryer on google or Dogpile. You should be able to find how to
put the Tension Pully back where it belongs & how to thread the belt through it and back on to the motor drive shaft. Check different sites for the right picture for your dryer. Here's a picture to get you started. Good luck,
Sep 13, 2010 | Kenmore 500 6952 Dryer
How to instal fan belt on 85 cadilac eldorado
You need to locate the tension pulley and by moving it with a wrench you will have enough slack to finish the job BE CAREFUL it can require a lot of power to release the tension
Mar 10, 2010 | 1985 Cadillac Eldorado
Do you have a way to find the route for a 1993 Ford Escort Serpentine Belt?
FOR A 1.9L ENGINE. CANT SEND PIC, START BY PUTTING BELT OVER ALTERNATOR PULLY,THEN TO THE RIGHT OF POWER STEERING PUMP PULLY FROM THERE TO THE LEFT SIDE OF THE IDLER PULLY , THEN UNDER THE A/C COMPR PULLY AND UNDER THE CRANK PULLY RELEASE TENSION ON TENSIONER BELT GOS UNDER TENSIONER.
Nov 04, 2009 | 1993 Ford Escort 4 Door
Cant put on belt right
from front of engine looking back,belt around bottom of crank pully,water pump is just above,left side of belt comes around water pump going counter clock wise,put belt over alternator,then straight across to a/c compressor,(make sure belt goes under any idler pullies,smooth side of belt to smooth side of pully)find your belt tensioner,pry back on tensioner(be carefull)and carefully place belt under roller pully of the tensioner,release and check allignment of belt prior to starting.oh ya make sure belt is in good condition.
Mar 01, 2009 | 1991 Chevrolet C1500
Morning replaceing alternator belt the long one for a mitibushi 2001 gallant. its the belt that goes around all the pullys. we get the belt on but how to tighten it up once in place.
Their should ba a tensioner pully that it goes around. this part keeps tension on at all times. It is possible that you have the wrong belt or you have the belt routed wrong. Check with your local auto parts store, they should be able to give you the belt routing and the right belt if you have the wrong one.
Please contact me if your problem presists.
Thanks, Charlie1221
Jan 30, 2009 | Mitsubishi Galant Cars & Trucks
I have a 99 mazda and i dont remember how the serpateen belts went do you have a diagram i can go by
hi there .there r two belts inner belt goes throw the crank pully ,through tensioner and the alternator .the outer belt belt goes through the crank pully agine to tensioner and the power steering pump .sorry i dont have diagram but thats the way it goes hope it helps do send me the rating thanks
Jan 20, 2009 | 1999 Mazda Millenia
Replacing the serpentine belt
loosen the tension pully
Aug 13, 2008 | 1997 Ford Windstar
Whirlpool WED5300S Electric Dryer Logo
180 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
