Question about Ovens
My NEWWORLD VISION 50 ECWLM electric cookers oven has recently stopped producing heat, please tell me what the problem is!
5 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
It would appear that the tripping of the switch has caused some kind of short within the cooker. I would look for the continuity of the heating element.
Most likely the wires leading to the heating element have burnt and will need replacement. If you are comfortable with attempting a DIY, well and good. You will have to open the back panel to access the said wires. It should be easy enough to identify..it will be the wire leadingto the heating coil.
If , however, you are not familiar with these kind of things, I would recommend getting a repair guy to do it for you.
Cheers and good luck with the repair!
IrishDruid.
Posted on May 26, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
SOURCE: how to change bulb on newworld g90 vision cooker
To change the bulb is quite easy, the glass lens screws off, give it a good soak and clean whist popping out to buy a new bulb, otherwise you won't notice the difference. Note the bulb is a special oven bulb, if yoo can't read the old bulbs rating it's probabily a 25W 230/240V rated for 300deg C - try Wilko's around £2.50
Posted on Aug 08, 2011
  • 4483 Answers
SOURCE: Can I fit a plug to new world vision 50 ecwlm cooker instead of electric box? Tried to find out if over 2.9kw but 2nd hand and no manual details
I have heard of people doing that and getting away with it - such is the capacity of the modern domestic ring circuit. Certainly no one should be doing it and no one with electrical knowledge would condone or recommend such a thing as if you didn't get away with it, it could burn your house down without blowing a fuse or tripping any safety devices.
The cables carrying the current to the sockets and light fittings traverse many flammable things between the power outlet and the electricity meter...
In an emergency you could fit a plug and use the cooker but never, ever more than one boiling ring and one simmer ring OR the grill OR perhaps even the oven if it is a conventional oven.
If you do decide to take the chance I advise you most strongly never to trust anyone else to operate the cooker and never to leave it unattended...
A large boiling ring is typically 1500/2000 watts and a small simmering ring is typically 800/1000 watts. I can't tell you what the consumption of the other equipment might be but it should be easy to discover as the manufacturer might have a downloadable manual on the website or you could try googling replacement heating elements.
You should have a cooker outlet installed as soon as possible.
Posted on Oct 01, 2016
Oct 01, 2016 | New World Ovens
My newworld newhome cooker's ignition does not work. Please could you tell me where the battery goes as I cannot find it.
The battery is in a case (plastic holder) left hand side right near the floor in the plinth, opening the oven door will make it easier to see. (Assuming I have the correct model)
Dec 09, 2013 | New World Ovens
NUMBERS MISSING FROM FRONT OF OVEN
if you get a solution could you tell me too please? Or do you have a link to where I can get a manual from please@
Nov 10, 2013 | New World 70TC Electric Single Oven
I have a Smeg SA 398x model. firstly, I would like to know the year of manufacture please. Secondly, for some reason the fan element options do not heat up. The fan in the back of the oven works but no...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 19, 2011 | Smeg Linear Pyrolitic Single Oven Electric
How to change bulb on newworld g90 vision cooker
Sep 18, 2010 | New World G90m Gas Double Oven
Newworld dfeo 90 main fan oven not heating - fan works! - which part most likely faulty
If it is an electrically heated fan oven, then I would suspect the oven element has failed, this is at the rear of the oven compartment behind a removeable cover.
If it is heated by gas, then I do not have an answer for you,as I have no knowledge of gas ovens.
Hope this helps.
Jan 30, 2010 | Stoves Ovens
Moved into a house with a New World 60EDOm fan oven and electric cooker, but we are missing the manual, would it be possible for us to be sent one?
Hi please would it be possible to have the manual for the Newworld 60edom, I have a problem with one of the rings on it seems to come off and on. Can not locate the manual anywhere.
Many thanks
Nov 29, 2009 | Ovens
Electicalal procedure for appliances The elements on my electric cookers oven of 6 years have recently blown when I turned it on. If I have on many occasions turned on the oven switch first before I have...
Hi there
I am a qualified electrician for more than 20 years.
You cannot blow the element by switching the oven switch on before the mains.If it has blown for any reason it will simply be because the element has a fault and needs replacing.
Hope that resolves your dispute.Please be kind enough to leave a comment to say i have solved your problem.
Thankyou
Aug 09, 2009 | Ovens
How to adjust clock? no Instruction manual!
I had the same problem... NO MANUAL.. I contacted Newworld who posted me a hard copy manual. I have scanned the manual into a PDF document. If anyone needs a copy, please email me at david.stevens@vibanalysis.co.uk and I will email you the manual. Happy Cooking
Dec 28, 2006 | New World E70DOa Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
