Question about Frigidaire GLEQ642A Electric Dryer
I would like to replace lint cover on Frigidaire Dryer AGQ86000ES2 I have the part and a new lint catcher as well. unscrewed the cover and found there are wires from the bottom of the cover going down somewhere to a connection do I need to take the front of the dryer off... and if so how Thanks
    President:
  • 3,074 Answers
That is a sensor, here is website that will help,Tim:
http://www.applianceaid.com/wwf-howto.html
Posted on Mar 12, 2011
DRYER MAKES NOISE WHEN DRYER TURNED ON SMALL PLASTIC PEICE FELL INTO DRYER LINT CATCHER
it may have worked its way into the b,lower. u have to remove cabinet and then remove blower cover and try to find it.
Aug 27, 2014 | Kenmore 500 6952 Dryer
My clothes are covered in lint
Hello Pam, Take the lint screen over to the sink and gently wash it in dish soap and water. Let it dry and try it. Sometimes the small holes in the lint screen plug up from using fabric softener and/or fabric softener sheets. It doesn't take much to restrict the airflow through the lint screen.
Feb 14, 2014 | Samsung DV330AE Dryer
I have a Maytag neptune dryer model # MDE5500AY. I smelled a smokey and electrical smell tonight. What's going on? Lint catcher is clean and I also clean around dryer. House was built in 2004 and dryer is...
the fault is lint build up around the dyer element the element must be cleared of all lint after years of use despite having a catcher lint does get into the dryer in time it will build around the heating element and start to burn this is unsightly but more so very dangerous as it does cause house fires have the element cleaned
best of luck
please rank this advice if you found it helpful
sonic boom electronics australia
Dec 28, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer SHOWS ERROR 68 ON PANEL and shuts off?
Error 68 can mean that your start button is stuck; check to make sure the button is not stuck in the pressed position behind the controls cover.
Apr 25, 2010 | Frigidaire Electric Dryer
My wife was cleaning the lint catcher and something fell inside of housing of the catcher. Is there any way to unscrew the dryer to get it out, or are we just out of luck? I don't want to start up this...
You should keep your hand grenades somewhere else! Remove the top (either screws in the back or control housing or push in each front corner with a thin putty knife to release the latches), and remove the screws on the insides of both front corners, then lift up to release the front panel. That should give you access to the blower housing and duct work. Retrieve whatever fell in and vacuum out all lint in the area while it is open. Be sure to wash the lint filter in hot water and detergent to get rid of fabric softener deposits which plug the filter screen. Check the drum bearings (either sliding pads or rollers) for wear. Replace if found to be in bad condition. Also, check the condition of the drum belt and replace it if it is cracked or breaking apart. You will need to access a lower rear panel to remove the belt from the motor and idler wheel. Hope this helps!
Oct 29, 2009 | Whirlpool Dryers
How do you check if the coin catcher is plugged on a frigidaire ftf2140fs0 washer?
Remove bottom pannel. you will see a black rubber boot.Undo the clamp that connects to the tub. Pull boot down a little and reach the top of the boot with fingers and pull out plastic coin catcher. Clean out and replace.
Oct 01, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Drum makes noise after I unscrewed the screws inside the machine.
You will have to remove the drum from the front and replace the drum support cup kit.
May 23, 2009 | Frigidaire FDE647RF Dryer
Where can I get a lint catcher for an Amana Gas Dryer Model No: LGA30AW.
Hi
You can buy a Lint Catcher/filter for your Gas Dryer from this link---
Amana Gas Dryer LGA30AW Lint Filter
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 28, 2009 | Amana Dryers
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Frigidaire GLEQ642A Electric Dryer Logo
27 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
