Question about RCA HD52W56 52" Rear Projection HDTV
The heads are cut off....I only have my dish remote, Is there a way to fix the format from that tv or a button on the tv itself it is a 52" or 60"
    President:
  • 1,654 Answers
How did this start? you need the remote to change the settings in the first place, somebody used it to change the settings! Have you tried using the dish remote, did you change the format on dish? there is a place on the remote that changes the format from the sat signal also, should be a yellow bar below the live TV button. This is the way mine is set up but on other remotes there is still a button to change the format, look on the dish remote for this.
Posted on Mar 12, 2011
The picture is too big cuts off heads and cant read on lower part of picture
Many remotes have the option to change the format pressing the star * button. You can also try change the zoom in your TV settings.
Mar 07, 2013 | Televison & Video
I have a Dynex TV and Dish Network receiver. Last year the TV worked fine, I don't think I changed anything, but this year the top of the screen is cut off when I watch NFL games. The top of the score...
You will need to press the "Format" button on your DISH remote This button will have a * on it. By pressing this button repeatedly, you can change the format of the screen set it to normal. Next grab the factory remote for your TV and try the different formats most likely normal will work best on this setting as well.
Daniel Busa
DISH Network
Customer Service
Aug 27, 2011 | Dynex DX-LCD37 TV
The picture seems to have gotten bigger and now the tops of their heads are cut off
When this happens you can try the wide/picture format/view mode button on your television's remote control first. If your remote does not have one or if this does not correct the problem check the resolution on the cable box next. If your television displays 720p make sure the cable box is set for 720p, or 1080i if the television supports that resolution. First you have to make sure your tv in on the right input not the tv tuner input. Then use the hdzoom# button on the cable remote. If you have a satellite remote it might say format or aspect or you might have to go into the cable box/satellite receiver menu and choose 1080i crop or 1080i stretch to get the right picture size.
Feb 12, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
The inlaws pushed about every freaken button on the remote,now the picture on our tv is way too big ,and the heads and logs etc are no longer there help !!! please
This formatting issue can commonly be corrected by simply pressing the (*) button on your remote this button is also known as the format button and is located in the bottom left corner of the remote, which is also to the left of the zero button. You can change the formatting of the tv picture by pressing the star/format button until the format is corrected. I hope this helps!
-Kirstie DISH Network
Jan 30, 2011 | DISH Network IR Remote Control
Insignia 32" 720p Flat-Panel LCD HDTV - High-Gloss Black Picture is too big for screen ,cut off all around, top, bottom and sides. Can't read things on screen, heads cut off etc. I've gone through...
try checking the menu setting on your Dish Network, there may be a television format in that menu set up, if it is only when a dvd player is playing, then check the format on that, so on so forth... that is one place to start, check if it is local (TV) or if it is from attached component ( Dish dvr/ dvd etc). also refer to your owner's manual.. if all else fails, call customer service @ insignia
Oct 17, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
I have a 52 inch SONY Bravia that has been stuck in zoom mode since last night. iI am unable to see the writing and/or tops of heads on top of screen. any help available?
Press the "WIDE" button on the TV remote a few times to change the TV wide mode settings until you get it to "FULL". If that does not fix it, look on your Cable box remote for an "Aspect" or "Format" button and press it a few times. I hope this helps.
Apr 19, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Tv continues to go to menu screen (not dish menu, tv menu)
sounds like a button is stuck. Remove the battery from the remote and see if this fixes the problem
Sep 07, 2009 | Televison & Video
Picture format to large
There should be a format button on your remote to change between widescreen & fullscreen as well as the zooms. May say format or aspect. If not on remote look through your menus. Make sure which ever u select u do not choose a zoom. This will cut of top & bottom of picture
Apr 06, 2009 | Televison & Video
RCA HD52W56 52 in. Rear Projection HDTV Television
turn off autoformat.. to change format push left or right arrow over on your remote
Oct 23, 2008 | RCA HD52W56 52" Rear Projection HDTV
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
RCA HD52W56 52" Rear Projection HDTV Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
