Question about Maytag Bravos MTW6600T Top Load Washer
I have a error code HC which means switched hoses hot and cold but i checked them and they are in the right location
    Scholar:
  • 177 Answers
Are you getting hot water when you should and cold water when you should? If you are sounds like screwed up electronics.
Posted on Mar 12, 2011
What does "HC" mean?
The HC code indicates that the computer thinks the cold water inlet is getting hot water. The hot water inlet has the cold water coming in. Take off the inlet hoses and double check your water lines. If needed, swap the connections. While you have the hoses off, clear the filters and check for leaks. Check the flow rate and replace the hoses if the water flow is restricted. (Anti-burst hoses can reduce the flow when they detect a leak.)
If the hot water supply is correctly connected to the hot water inlet, then the electronic control board is getting faulty information. Unplug the washer for several minutes. If the code repeats, then the valve may be faulty. Alternative causes of the problem are the hoses, the wiring or the control board.
I hope this helps.
Mar 16, 2016 | Whirlpool WTW6400SW Cabrio Washer
What causes error code Hc?
This error code indicates that the cold and hot water inlet hoses are switched.
This code will appear at the end of the wash cycle to indicate that the cold and hot water inlet hoses are switched. If an error code does not appear, but you are experiencing poor wash performance, check to see if the inlet hoses are reversed.
May 12, 2015 | Washing Machines
SYMBOLS ON THE PANEL
That means that you have the hot and cold hoses hooked up to the wrong inputs. Switch them.
Feb 02, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What does it mean when the washer goes all through its cycle and says clothes are clean but has an error code displayed saying HC??
Interesting. Lets look at the TECH SHEET. HC hot cold reversed. The inlet hoses are connected bass ackwards. Connect the cold to the COLD inlet and the hot to the HOT inlet and the on board processor will work much mo betta I garontee. As shown on page 5.
Jun 19, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error message
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched.
If the hoses are not switched it could indicate a problem with the Electronic Control Board.
You can try to rest the washer by unplugging or flipping the breaker to the washer for 2-5 min.
Restore power to the washer and try running a short cycle.
This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 13, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does HC code on washer mean. Do not want to know how to fix it at this moment, just what does it mean
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched. If the hoses are not switched it could indicate a problem with the Electronic Control Board. You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min. Restore power to the washer and try running a short cycle. This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$#@!
Apr 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What does HC stand for?
According to the Whirlpool "Cabrio" washer installation and maintenance manual, (Cabrio is the Sears Oasis) the HC code will come up when.
“HC” (Cold and Hot hoses switched)
poor washing performance, check to see
whether the inlet hoses are reversed. See
“Connect the Inlet Hoses.”
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I need to know what the HC code means?
Aug 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
734 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
