Question about Logitech Harmony One Advanced Universal Remote with Color Touch Screen
While charging the unit becomes hot near the top of the remote. The screen then has a blacked out circle in it.when the unit cools the screen returns to normal. Can this be repaired?
  • 1,606 Answers
Yes, if you can get inside the remote control. For some reason the power management circuit is overheating and this is overheating the display. If it happens too many times, it could ruin the display. Fortunately, you know exactly where the hot part is; the only question is whether the part itself is the problem or something else is causing it to run hot.
If the hot part is the battery, you definitely want to get it repaired. The charger may be running at a dangerously high rate, or the battery is defective (assuming the temperature exceeds safe limits; some heating is normal). Check your warranty. Report this problem immediately to the manufacturer for possible recall action, even if the warranty has expired, and include the Product ID number as well as the model number (more information is provided on the manufacturer's page). Overheating batteries can explode, so they are considered a safety hazard.
Posted on Mar 12, 2011
Where is the defroster
Defrost on most units works like this. An electric wire heater is embedded in the cooling coil where the air is cooled. A timer periodically shuts off the refrigerator and turns on this electric heater coil which melts the frost off the coil. The water from this defrost collect s in a trough below the coil and drains down thru tubes into a shallow plastic tray under the unit. The water does not collect there but is evaporated over time by the hot air that blows over top of the water by the fan that comes back on when the refrigerator returns to cooling cycle. This is the fan that sucks air from the room over the condenser coil under the fridge to make the refrigeration work. The air is warm after passing over the condenser coil and then the air passes over the water tray. You can feel the warm air returning back into the room if you out your hand down near the floor.
Mar 16, 2014 | GE GSS20IEP Side by Side Refrigerator
Overheating battery ms5800
contact the manufacturer
Jan 26, 2013 | Computers & Internet
Running very hot and shutting down
You are running into a CPU overheat issue.
1. can you feel or hear the cooling fan come on at all? If so try and use compressed air can to clean it out.. they get tremendously dirty. You can also try a vacuum hose, but cover nozzle with hand and only hold next to cooling fan outlet and nowehre else with laptop off and unplugged. Dont get near keys or other parts as will damage. Dont use SHOP VAC either.
2. If Cooling fan is NOT Coming on you can try a laptop cooling pad. these are external units by Targus and other companies that have cooling fans to supplement a laptop units cooling fan. You can try this to see if airflow is your problem.
3. If you recently ran encryption software, a new antivirus program, or upgraded to Windows 7 it is possible that your culprit is the unit is not cycling. Meaning the hard drive is continuously being accessed and the CPU is in constant service... this can cause overheating as well.
Jun 02, 2010 | Toshiba Satellite A135-S2276 Notebook
Cannot shut off & no display
The eMachines M5105 is notorious for failing to boot if left unplugged and powered off long enough for the battery to become mostly discharged. Plugging it in to AC power will cause the battery to start charging; and the hard disk drive to spin while the CPU cooling fan cycles on and off vigorously. THE UNIT WILL NOT BOOT UNTIL THE BATTERY IS NEAR FULLY CHARGED; then THE AC DISCONNECTED; and then THE (charged) BATTERY REMOVED AND RE-INSTALLED! Most units will boot after following the foregoing procedure.
Jun 24, 2009 | E-Machines M5105 Notebook
UNIT RUNS ALL DAY AND NIGHT WILL NOT COOL UNDER 78 DEGREES-ALSO WILL NOT EVEN HOLD AT 78 DEGREES. HAD THIS UNIT SERVICED OCT 29, 08. IT IS STILL UNDER WARRANTY-BUT WAS CHARGED 700.00. CAN'T AFFORD TO GO...
it sounds like thermostat which tell unit to turnoff
and set the temp. you can test them with hair dyer buy putting it on heat see what dose then cool. The display should show the temp. if so then it should shut off or turn on is. If not could be a bad thermostat. Or is the thermostat in a hot spot in the house is should be near the return. Hope this helps. Yes I do for living Paul
Jun 19, 2009 | Heating & Cooling
Hdtv with yellow half circle on bottom of screen
Odds are real good that the cooling fluid in the blue picture tube assembly has become contaminated. Only solution is to pull blue crt and dump out old fluid and clean and reinstall new fluid. Once done a fair amount of re-alignment is required. This is not a job for a do-it-yourselfer. Most tv shops would charge in the area of $250 to $300 for this repair.
May 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Connection screen
Reset the player - manual has instructions
Remote possibility:
Use the Thumbwheel to rate the song (1 to 5 stars) then press
|<< button to return to Music Options menu. My Top Rated
Songs can be viewed in MUSIC menu.
Dec 26, 2007 | SanDisk Sansa e260 MP3 Player
Sharp Aquos 37 inch LCD HDTV - black trails on picture when hot
LCD LAG COMPENSATION CIRCUIT? never heard of that, dosent mean it dosent exist, you may have a LCD driver board issue, never seen the trails thing on Aquos, have had to update the software on many of these critters though.
Jul 07, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Handset gets warm on charging stand
The handset and the AC adapter can become warm. This is normal operation on this unit. If it is too hot to touch, your unit is need of repair.
Dec 03, 2005 | Vtech IP5821 Cordless Phone
Logitech Harmony One Advanced Universal Remote with Color Touch Screen Logo
153 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
