Question about Epson Perfection 4490 Office Flatbed Scanner
Scanned 35mm slide comes out as rectangle with dark edges
I am scanning 35 mm slides in the professional mode using the 35mm slide holder.
The slides are square but the scanned image is rectangle. This causes a dark strip on the sides to compensate for a "square original in a rectangle space"
Online Epson support said I'd have to scan each slide and crop the edges. Kind of defeats the use of the slide holder.
Do I have setting wrong
  • kansasgal Aug 08, 2008
    You are correct. I used the wrong terninology. The 35mm slide I am scanning is held in its outer square "mount". The mounted slide fits exactly in the square holder that comes with the scanner and allows for 4 slides to be scanned at once. This is why I referred to it as "square".
    To me it appears the scanner should scan it is a square, since it is set up that way.
    Kansasgal
  • Anonymous Dec 03, 2008
    I'm having the same problem.  My square format slides are automatically cropped to a rectangle when scanned.  I can occasionally get it to scan one correctly if I flip it over, rotate it or shift the 35mm slide frame over.  Annoying.
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
Posted on Aug 04, 2008
The 35mm strips won,t fit in my holder how should I be inserting them in the holder
The holder that takes 35 mm negative strips on one side and 4, 35 mm slides on the other has a plastic frame that holds the 35 mm film in place. To load film you have to first remove that frame by putting your finger in the opening by the large "A" and popping that end up. The frame fits in only one direction and must be clipped back in by first engaging the two small fingers into openings at the end opposite to the "A" and the lowering the retainer down snapping the 3 sets of 3 clips as you work toward the "A".
Oct 11, 2014 | Epson Perfection V500 Flatbed Scanner
Scanning 110 Instamatic slides on Epson Perfection V700 photo scanner
Hi Stanley - does this youtube video help? http://www.youtube.com/watch?v=EcALdbbCnSk
If not, let me know and we can investigate further.
Regards,
Justin.
Jan 17, 2014 | Epson Perfection V700 PHOTO Flatbed...
Does the HP photosmart 2710 scan negative ansd 35mm slides?
This multi function printer/scanner cannot scan 35mm slides and negatives.
Some flat bed scanners with a lighr scource that shines through 35 mm slides and negatives can scan them.
You will be better off getting a dedicated 35 mm slide/negative scanner.
Check out this WEB site foe slide scanners.
http://www.google.com.au/#q=35mm+slide+scanner&hl=en&prmd=imvns&source=univ&tbm=shop&tbo=u&sa=X&ei=dYFIUPKBKMSyiQedl4G4DQ&ved=0CEkQrQQ&bav=on.2,or.r_gc.r_pw.r_qf.&fp=4469b7ccc4340a33&biw=1016&bih=535
Sep 05, 2012 | Epson Office Equipment & Supplies
Will not recognize 5th image on negative strip because 4 and 5 overlap (slight double exposure). How do I scan 5th image?
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Jun 16, 2011 | Nikon Super Coolscan 5000 ED Film Scanner
How to copy 35 mm slides
Read any of the online articles at:
http://www.bing.com/search?q=copy+35mm+slides
for information about "copiers" for 35mm slides.
Nov 11, 2009 | Epson Perfection 4990 Flatbed Scanner
Getting true color on slide scans
Make sure you have the emulsion (image) side of the slide towards the scanner sensor. Some scanners have a special setting for film still in slide holders to correct for focus. You may need a photo edit program to help with color and density. I find no difference from 35mm to split 5x7s altho bigger is always better.
Jul 03, 2009 | Nikon LS-9000 Film Scanner
Color balance is bad
Have you tried cleaning the slide holders/adapters?
Jun 11, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
The 2400 Scanner quit scanning 35 mm slides as the top lid light
problem in the driver so pls check latested driver in the internet and download it then you problem will solved
Mar 17, 2009 | Epson Perfection 2400 Photo Flatbed...
After scanning one photo slide and storing it on my computer, I can't delete this first scan to scan another
It's not necessary to delete the previous scanned photo. To scan another slide, place it in the scanner and press the PREVIEW button.
Mar 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Epson Perfection 4490 Office Flatbed Scanner Logo
397 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
