Question about Troy-Bilt Garden
I have troy bilt tiller super bronco model 21A-643B711, serial 1B076K60134. I bought new drive belts: forward 1916657 , 2610 (replaces old number 754-04090 in manual), reverse belt seems to work. I installed both belts, replaced all guides and guards. I checked and followed "install forward clutch cable" and "check for correct tension on foward drive belt and taking measurements on cable spring" "checking and adjusting forward drive belt tension" per manual. That all is done right. I checked all springs etc... The machine works great in reverse and the tines move regularly. The machine will not move forward and the belt feels very loose when pressed on both sides to touch idler pulley there is visual belt slack above the drive pulley that you could stick a pencil in easily. It seems like the belt is too big.
SOURCE: I need a manual for my MTD Huskee 5hp rear tine tiller
I went to MTD web site and they had all the manuals for all there products. You will need a model and serial number to get them. Thank you for responding back to me.
I got the manual for the tiller and the engine.
Posted on Apr 13, 2009
SOURCE: BELT PLACMENT ON TROY BUILT TILLER MODEL
I am assuming your belt broke and you cannot find the replacement.
I had to go to an old timer that owns his independent business and he was able to find a much better belt than the one that came on the tiller. The Belt # is 1916657 and it is 25.5 inches long and 1/2 inches wide. It also has a kevelar core that will stand up to the constant gearing up and down.
Lowes was NO HELP AT ALL!!!!
Hope this at leasst get;s you in the right direction
Posted on Apr 25, 2009
  • 45 Answers
SOURCE: troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Posted on Apr 29, 2009
  • 69 Answers
SOURCE: does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Posted on May 06, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
I had this same problem and took the first advice about the shift fork arms being too spread apart. I took apart the gearbox apart and found that the shift fork arms did indeed spread apart overtime and with wear. I'm having a buddy weld some reinforcement to it as long as he can maintain clearance in certain areas as to not disrupt the operation. If it doesn't work then I did find the shift fork assembly part for $50, I just googled the part number, clicked on various sites, and found a better price!
Posted on Mar 03, 2010
What is the spark plug gap for the engine of a troy bilt super bronco crt tiller
go to troy blit and input model number, this will tell you what you need to know
Jan 22, 2015 | Troy-Bilt Super Bronco 16-inch 208cc...
How do you get the belts off of the super bronco tiller
There is a tennsioner for the belt that you can loosen up to remove the belt. There is a screw that loosens up the belt tensioner.
Good luck.
Jul 27, 2011 | Troy bilt Super Bronco Tiller 208cc
How can I get a Owners Manuel for Troy Bilt Tiller Seril no. 722649
Hi and welcome to FixYa. I am Kelly. We need the exact model number to be of any help in trying to locate a manual for you.
If you have your model and serial number you can use this link.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
Thanks for using FixYa.
Kelly
Apr 23, 2010 | Mtd Troy-Bilt Bronco OHV Tiller
How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Jun 24, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
BELT PLACMENT ON TROY BUILT TILLER MODEL 21A-643B711 SUPER BRONCO CRT
Apr 17, 2009 | Troy-Bilt Garden
Garden Logo
159 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
