Question about Toshiba 50A61 50" Rear Projection Television
Toshiba 50A61 have sound but no picture - Toshiba 50A61 50" Rear Projection Television
  • 31 Answers
Make sure correctly hooked up in back of TV. Then in menu go to audio and be shure that speakers are set to ON. Most TV's you can turn the speakers on and off in the audio menu. If they are still off you might have bad speakers and need to replace them.
Posted on Mar 12, 2011
4 Suggested Answers
TOM2-TOM2
  • 110 Answers
SOURCE: I have sound and no picture
These unit will mute the video for a number of reasons. F889, F890, F891, F850, F470 one of these fuses is open then fine out what caused the fuse to open. This an older unit so parts may be hard to find. The cost to repair it should not be to bad.
Posted on May 14, 2009
  • 11800 Answers
SOURCE: I have a 2001 model # 50A61 52" Toshiba TV. I was
the pop was the sound made by an electrolytic capacitor exploding. Yes, the tv is fixable, all depends on what other parts were damaged when the capacitor failed the big way. Worst case scenario - the entire power board will gonna have to be replaced: $350 board and labor. But on a tv this old all the other components have aged so it might be just the first one of an long line of failures.
If you have the money, just get a new, better tv, it will be cheaper in the long run.
Posted on Sep 05, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a toshiba 50a61
Hi ogmrwizzard,
This is an indication of faulty lamp.
First check the lamp connectors, pull-out, inspect the connectors and then re-insert and ensure its connection from the ballast board. If the symptoms still persist, you must replaced the lamp to back the picture again.
Hope I helped you.
Thanks for using Fixya.
Jdvillanueva
Posted on Jun 04, 2011
I have a toshiba 50a61 projection tv, it shows the menu and comes on but does not show a picture or sound.
I highly recommend you call a technician before you hurt yourself or cause more damage to the TV
Dec 08, 2014 | Toshiba 50A61 50" Rear Projection...
Colors are seperated on toshiba 50A61
Go into menu and with original remote call up convergence--either it has a problem(will not adjust) or you may with the remote be able to manually adjust the convergence back: sometimes if a power outage/surge it scrambles the convergence memory.
Aug 28, 2012 | Toshiba Televison & Video
Toshiba 50A61 have sound but no picture - all fuses check okay
Not too many--if sound is developed from the set and not a surround system the set will blank the 3 picture tubes for a few reasons:
Voltages missing at the tubes (high voltage or screen voltages etc)
There is a loss of vertical sweep or horizontal sweep--set will do here this to prevent an INSTANT burn mark on all 3 tubes.
One thing you can try to look for is to see if the filament in each tube is lit---rather dim as 6.3 volt one---if lit the above reasons are your problem.
Without a meter, a schematic etc not much more you can check.
You should hear a faint whoosh sound when you power the set on--the high voltage coming up.
Jun 07, 2012 | Toshiba 50A61 50" Rear Projection...
I have a toshiba 50a61 tv sound no picture
Hi ogmrwizzard,
Hope I helped you.
Jdvillanueva
Jun 04, 2011 | Toshiba 50A61 50" Rear Projection...
I can't get the red gun on my toshiba 50A61 tv to center with the green & blue
Ur convergence is dead,must repaced parts.Know how to solders?Buy a convergence kit.Tries Tv repair World.com,Tv repair kits.
Dec 11, 2009 | Toshiba 50A61 50" Rear Projection...
Toshiba 50A61 Horizontal Lines in picture
You have bad connections somewere need to look further for sure
Nov 08, 2008 | Toshiba 50A61 50" Rear Projection...
No picture or sound.
http://www.vancebaldwin.com/models/?TBA53AX61
Part Number Decription 23236623 #T461 FLYBACK TFB3086AD 24083013 #Z401 NOTE **SEE 50A61 FOR MAIN PARTS LIST ** 23549258 BEZEL 23427995 DOOR 23905094 IC STK392110 23311899 LENTICULAR SCREEN 23405040 MIRROR 23565302A OWNERS MANUAL 23311859 PROTECTIVE SCREEN 23306370 REMOTE 23311892 SCREEN FRESNEL CDSMPJTV03 SERVICE MANUAL (CD) 23527210 SPEAKER GRILLE
Feb 03, 2008 | Toshiba 53AX61 53" Rear Projection...
Toshiba 50A61..power comes on but no picture or sound
There are fuses in this unit, one could be blown there are also capacitors and a regulator that could be at fault I would suggest U find a repair man in your area if possible to go thru this unit find the fault and repair. It would cost less than to repair than buying a new one.
Jun 16, 2007 | Toshiba 50A61 50" Rear Projection...
Color problem with Toshiba
Sounds like a problem with convergence, poss just requires new STK 392-110 ICs , may need a couple of resistors that go due to faulty ICs
Nov 02, 2006 | Toshiba 50A61 50" Rear Projection...
Toshiba 50A61 50" Rear Projection Television Logo
160 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
