Question about Roper Refrigerators
At times my refrigerator will act like it is defrosting. Dripping water from he freezer section into the shelves, drawers and door. Is there something I should be doing?
Sounds like your defrost temp sensor may not be turning off.
Posted on Mar 13, 2011
Water is leaking from an opening in the back surface of the freezer compartment and forming a puddle that freezes and then melts, dripping under the freezer door
If you remove the shelves and bins from the lower section of the freezer you will notice in the back of the freezer your drain pan is clogged. Turn off the freezer and use a turkey baster to add hot water to the pan until you clear the clog. This can happen when foreign object slow the water leaving the freezer during defrost and cause it to refreeze stop water from leaving the freezer. Not a big problem or difficult repair. Just clear the drain and remove all the ice from the drain pan. Could take 15 mins or so to complete this..
I hope this helps
Jul 26, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dripping from freezer area down in refrigerator water collecting under crisper drawer.
This is most likely due to the defrost drain being restricted, see the link below and let me know if it helps.
Defrost Drain
May 20, 2010 | Refrigerators
I have water dripping from the freezer into the refrigerator and refreezing in the drawers. How can I find where the water is coming from and correct the problem?
It is leaking due to a clogged drain line between the bottom-rear of the freezer section and the drain pan underneath the refrigerator. Remove cover in the back of the freezer section. there will be a small drain pan under the cooling coil. Remove ice, defrost with hot water and clean/blow the drain line.
Apr 16, 2010 | Estate TT18TKXKQ Top Freezer Refrigerator
Water is getting into the refrigerator. there is
If the fridge has the freezer on top - the problem is in clogged drain under the evaporator.Whenever the defrost cycle is activated (every 6-12 hours), the water will drain not to the drain pan underneath the fridge, but into the air vents between the sections. Depending on the make/model to get to the drain line you may need either:
  • to remove the back cover in the freezer section;
  • remove the bottom of the freezer section;
  • remove the console with controls on the ceiling of the fresh food section
  • get behind the fridge, find the drain line going to the pan under the fridge remove the drain line and clean.
Good luck.
Vlad
First Choice Appliance
Mar 13, 2010 | Refrigerators
Freezer . Food is chilled not frozen. Checked troubleshooter suggestions in book. eg A small bottle water left in freezer overnight is only cold. Can hear the fridge humming along . All the sounds are the...
looks like a blocked evaporator. 1st course of action would be to carry out a 48hr total defrost... signs are external frosting on rear panel at the bottom of freezer unit behind shelves or drawers...
Dec 18, 2009 | Whirlpool Refrigerators
I have a 10 yo kenmore coldspot refrigerator. We
I had the same problem. The water resovior in the back of the refrigerator had a pin hole in it.
Jun 30, 2009 | Kenmore Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Roper Refrigerator
open the freezer compartment loo for ice build up on floor of frezer especally towards rear behind back panel. sounds like you have a clogged/frozen defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials)
Mar 05, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Water dripping from top of fridge (coil housing?) under freezer.
I HAD LEFT THE DOOR AJAR ON MY KENMORE DPOUBLE DOOR WITH TOP FREEZER AND IT FROZE UP NOT ALLOWING THE WATER FROM THE NORMAL AUTOMATIC DEFROSTING PROCESS TO GO DOWN THROUGH ITS NORMAL DRAIN. THE ACCUMULATED WATER THEN DRIPPED INTO THE REFRIGERATOR UNDER THE FREEZER AND HAD TO BE SOAKED UP DAILY. THE SOLUTION--I REMOVED THE ADJUSTABLE
THATBOTTOM PLATE HAD AN UPWARD CURVED PORTION AT THE REAR. WHEN RE-MOVED, YOU COULD SEE FROZEN ICE ACROSS THE BACK UNDER THE VERTICAL COVER THAT COVERS COILS(?).
IN THE FAR BACK BOTTOM THERE WAS A FULL LENGTH, APPROX 1 1/2" WIDE DRAIN AREA WITH A HOLE IN THE CENTER THAT WAS PLUGGED WITH ICE.THAT WAS PREVENTING THE NORMAL DRAINING PROCESS.
A HAIR DRYER AND ABOUT 15 MINUTES MELTED THE PLUG, I THEN POURED A GLASS OF HOT WATER INTO THE HOLE AND IT DRAINED RIGHT DOWN LIKE IT SHOULD.
I HAD THE SAME FREEZE UP & DRIPPING PROBLEM A COUPLE YEARS AGO AND IT COST ME $100 FOR A SERVICE MAN TO FIX IT BUT IT'S REALLY A SIMPLE PROCESS TO FIX.
Sep 11, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
41 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
