Question about Datel WiFi MAX for DS (NDSWIFIM)
I have set up a successful connection, however when i try to connect it tells me that the connection is busy and to try again later.
Im trying to call my job and it keeps saying call failed the network is busy try again at a later time , whats going on ??? i need to make this call . its not letting me make any texts either !
Try resetting your Phone (shut it off and then on again)
Try calling a friend to test your provider's network. to be sure the problem isn't with the network at your job.
It's most likely a connection/data issue with your phone.. resetting it should work.
Also, double check your connection settings.
And why does this say "Problem with the Digital Cameras"??? This is a phone issue!
Apr 14, 2011 | Cameras
Tip
How to solve wifi issue in WINDOWS VISTA
Hi,<br /><br />How to solve wifi issue in WINDOWS VISTA when getting this error message"The settings saved on this computer do not match the requirements of the network"<br /> <br /> - Go to Network and sharing center <br /> - The go to manage wireless connection <br /> - Right-click on the SSID, and then select Properties.<br /> For WPA2 Users:<br /> - Under the Security Tab, set Security Type to WPA2-Personal.<br /> - Set Encryption Type to NONE. (Or you may select AES if its selected as TKIP or vice versa)<br /> - Set Passphrase.<br /> - Click on OK.<br /> - Then try to check your connection?<br /> - If you cannot still browse a website then try to go back to,<br /> - Start and select connect to and find your network name and click connect<br /> - Input the key and connect again <br /> - If it tells you that it was successfully connected, then try to browse a website <br /> - If not, change the SSID or your <a href="http://forums.techguy.org/#">wireless network</a> name<br /> - Then connect to your network again (Start and select connect to and find your network name and click connect, Input the key and connect again)<br /> <br /> <br /> If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response<br /> <br /> Thanks,<br /> <br /> LETMEFIXIT<br /> <br />
on Feb 02, 2011 | Computers & Internet
After installing zoosk messenger, it keeps trying to connect without success
The zoosk server might be busy - try again later. If it fails again, a few minutes of waiting, re-install the messenger.
Jan 20, 2011 | Sony Computers & Internet
Network Error (tcp_error) A communication error occurred: "" The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish...
This can be :
1-Your ISP has connection problems or connection speed is slow
2-The server you try to reach is busy at that time.
3-Or if you are under a network,the network itself is having connection issues.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 13, 2010 | Facebook Social Network
Internet problems
1. check the connection cable (try any other)
2. reinstall the phone driver
3. re-configure the internet settings
4. server problem (try connecting at night time)
Dec 31, 2009 | Motorola Mobility RAZR V3
"SERVER IS BUSY, TRY AGAIN IN A FEW MINUTES" Broadcasting problem
theres no problem in your webcam but definitely you have a problem in your messenger. try re installing the messenger, will surely work.
Jul 15, 2009 | Labtec 961307-0914 Webcam
I have a blackberry storm and im trying to pair my bluetooth h700 with it. it found the headset but it keeps saying connection successful the 2 seconds later itll say connection terminated. all my...
Hold down the connect button on headset until steady purple light comes on, then open the boom.
Search for Bluetooth devices on the phone. When asked for a pin, use "0000". Now the H700 will show up in the Bluetooth device list, but it will not connect. Put the headset in pairing mode again, this time go to the h700 listed on the phone and select connect. Now the devices will work as normal. When you open the boom on the h700, it will connect to the phone.
Jan 18, 2009 | Motorola Mobility H700 Wireless Headset
Cannot use my a4techpk710mj 5mp web cam
how can i install my A4tech viewcam i don't hav the cd and my cou does not have cd driver?
how can i install cause I lost my cd driver for A4tech viewcam camera
Nov 15, 2008 | A4tech PK5
Motorola v400
You need to set up your motorola to enable web browsing, you can do this on the internet.
Go to:
http://hellomoto.wdsglobal.com/site/phonefirst?%27&locale=en_GB&preferredCountryName=GB
Jan 27, 2008 | Motorola Mobility V400
Datel WiFi MAX for DS (NDSWIFIM) Logo
Top Datel Computers & Internet Experts
David Payne
David Payne
Are you a Datel Computer and Internet Expert? Answer questions, earn points and help others
