Question about Motorola Mobility RAZR V3
PROBLEM WITH RAZR CAMERA
WHEN I PRESS CAMERO THE PHONE LOCKS UP AND WANT LET ME DO ANYTHING.HAVE TO TAKE THE BATTERY OUT TO ABLE FOR THE KEY PAD TO WORK.WHAT CAN I DO?
  • Anonymous Aug 01, 2008
    Mine does the same and I know two other people who has the same problem, must be a glitch this phone model has.
Como posso instalar o programa de filmagem no meu v3?
Posted on Aug 01, 2008
Camera: new picture deletes previous one
try checking the settings for your camera, remember what you have done lately on your phone and bring it back to its previous state. play with your camera settings, try a little bit of experimenting on your camera settings and match it with restarting the phone. if this doesn' help you, you may try updating the phone camera firmware itself.  i would not guarantee that this will work but at least give it a try.   1.  from your keypad menu type this code *#6984125*# it will give you the admin setting 2.  select internals 3.  press the message box and type the code *#9072641*# press done, press confirm 4.  select test mode 5.  select video by pressing 6 in the message box and press ok. 6.  press 3 ; camera firmware update 7.  wait till it says success or complete 8.  press back , press end key (call end key) 9.  then restart your phone.
hence, you can do a hard reset or factory reset if you feel you don't want to do the steps above. to do a hard reset or factory reset do the following steps. 1.  back up your files, ex.. contacts, task, notes, photos images stored on your phone memory 2.  disable any locks or security locks, ie, privacy locks, sim locks, network locks.  3.  switch it off, remove battery, sim and memory card 4.  reinsert battery, make sure it is fully charge.. 5.  switch it on 6.  from your keypad type the code *2767*3855# 7.  the phone will do a hard reset and will reset to its factory setting.
be aware that it will remove all user settings from your phone.
good luck and regards.
Mar 07, 2010 | Samsung Jet S8000 Cell Phone
Water damage
open the phone and wash it if it does not works then change the keypad patta .
Aug 07, 2009 | Motorola Mobility RAZR V3
Press any button and phone does nothing
take the battery out without switching it off and put it back again it will work fine.even i used to have the same problem.after doing this back up everything and reset your phone you wont have the problem again.
Jul 14, 2009 | Motorola Mobility RAZR V3m Cellular Phone
My Razr V3xx won't turn on
I've had two RAZR phones die in the same way. The first time I went into Cingular to see if they could fix it and they told me it was a goner. It was replaced under warranty. I had one die that way a week ago as well, and got that replaced. The first time, I lost every number and address I had in it. This time I had it all saved to the SIM card so I could upload it to the new one. Sad fact is, that phone is most likely done for and the numbers are lost.
Jul 29, 2008 | Motorola Mobility RAZR V3
Cell phone
I had a problem very similar to this with my Razr but my service was through Verizon. I took it into a Verizon store and they thought that a software upgrade would fix the problem. It didn't. Fortunately, the phone was still under warranty and they ended up replacing the phone.
Warranty on the Razr is one year.
Feb 11, 2008 | Motorola Mobility RAZR V3
RAZOR V3
HAS IT BEEN WET? IF SO OPEN BATTERY DOOR AND REMOVE BATTERY THEN POUR RUBING ALCOHOL NOTE MUCH THEN VACUME NOW PLACE IT UNDER POWERFUL FAN OVER NITE.TRUST ME IT WORK'S...
Feb 01, 2008 | Motorola Mobility RAZR V3
V3 key pad locks up
you need to replace the flex cable in the phone
Nov 22, 2007 | Motorola Mobility RAZR V3
MotorolaV3x locks up when accessing camera or camera menu
You could try opening the top part of your phone and unplug and replug the camera connector. unscrew and pop open the case. The wire for the camera is the wide one on the left. flip open the lock(brown plastic), take it out, put it back in and flip back the lock.  good luck!
Oct 04, 2007 | Motorola Mobility RAZR V3
Razr v3 cell
Is your phone been dropped? or in contact with liquid? Check our local service center if they could find any phgysical damage on the phone.
Aug 10, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Stupid phone
Contact Motorola directly. They are very good about warranty and will most likely overnight you a replacement.
Aug 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
37 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
