Question about Celestion S80 Subwoofer
I have a Celestion S-80 sub woofer, and have searched the net, and can find no where a owners manual. does one even exsist? if not in what position should the switch on the back be in, that shows eather auto or manual it is a very small white switch. Thanks, Jon
    Brigadier General:
  • 8,546 Answers
If you've seen one powered subwoofer, you've seen them all.
I bet this Klispsch manual tells you everything you need to know.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Klipsch-KSW-10-Subwoofers-manual/id/11225dj093/t/2/
Posted on Mar 12, 2011
Testimonial: "Thank you, dunnbiker, your info was very helpfull"
What color is the wire for the subwoofer on the Kenwood KDC-400U
The sub-woofer isn't connected to the wiring harness of the KDC-400U. It has to be wired separately. Then the sub-woofer input gets connected to the KDC-400U sub-woofer out using R/L audio wires as show on page 13 of the Quick Start Guide. The direct link to the Quick Start Guide is http://manual.kenwood.com/files/4fd9a24acb9fa.pdf . You may be able to use the wiring information on pages 12-13 to help you determine which wires aren't going to the sub-woofer.
Most Kenwood Car audio manuals are available here: http://manual.kenwood.com/en_contents/search/ .
I wish that I could give you more information.
Apr 28, 2017 | Kenwood Car Audio & Video
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
How do I set up a Celestion S10 Subwoofer...
OK
Voltage is relevant to where you live in the world. America it's 110. Europe mostly 220.
What you're asking is a very deep and complicated question.
I'm attaching a link with some articles.
What I suggest is that you find an upper end audio store and ask a 20 audio head to set up your system for you. Subwoofer Setup and Calibration for Best Bass
Apr 12, 2014 | Celestion S10 Subwoofer
HI I BOUGHT HT-S6300 3D-Ready Home Theater System 2 DAYS BEFORE. MY SUB-WOOFER IS NOT WORKING. NO SOUND IS COMING OUT EVEN BLUE LIGHT IS ON. I HAVE CHECKED SPEAKER CONFIGURATION, AND IT GIVES SOUND TO ALL...
Check your owners manual.You will probably have to activate the sub woofer outlet,using the remote.This outlet can usually be programmed to do more than one function.
Jun 18, 2011 | Onkyo Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
I would like a manual for my sony sub woofer model sa - w305.
go to www.sony.com . Click on service and support, then click on product support, choose owners manuals and search for your model number. if they dont have it its no longer avalible. Steve
Dec 18, 2008 | Audio Players & Recorders
I need to buy a replacement woofer and tweeter
http://www.usspeaker.com/homepage.htm
http://www.speakerdoctor.com/diaphragms.html
both these companys deal with celestion speakers,for replacments go to usspeaker,to have the originals repaired go the speaker doctor.both have 800 #'s.now which to do is a matter of money.also make sure you don't have a blown crossover(its rare for the high & low freq drivers to go at once)this is usualy crossover related.happy hunting.hope this helps.thanx for using fix-ya!!! p.s.(please tell me you did'nt try best buy:) :) :) HAPPY HOLIDAYS!!!!!!!!
Nov 29, 2008 | Celestion A1 Main / Stereo Speaker
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
Open Questions:
See all Celestion S80 Subwoofer Questions
Celestion S80 Subwoofer Logo
820 people viewed this question
Top Celestion Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Rankin
Richard Lindsey ...
Are you a Celestion Audio Player and Recorder Expert? Answer questions, earn points and help others
