Question about Elna Sewing Machines
The top sewing thread feeds into the bobbin chamber and gets tangled. The top thread will not draw up the bobbin thread. This a Quilters Dream 2
  • Elna Master
  • 1,133 Answers
I'd suggest that you rethread the top thread entirely, ensuring the thread is going through the tension discs correctly and that the tension dial is set to the medium setting, usually 4 or 5.
If you have your manual, also check the cleaning instructions and see if the manual gives instructions on how to clean the tension discs, some of the newer machines these are hidden away but earlier models, you just turned the dial to zero, then ran a piece of clean cotton scrap selvedge edge through between the discs to clean out.
Also, if the machine is not drawing the bobbin thread up to the needle plate during a stitch sequence, check that your needle is not in backwards. Must be flat shank to the back.
Finally, if you are getting thread birdnests in the bobbin area a lot, remove the needle plate and follow your manual instructions to remove the bobbin holder and clean under it. The bobbin holder looks like this and sits in a surround.
The top sewing thread feeds - tally_girl_12.jpg Check that this case hasn't been damaged by the needle, there may be little piercing or burring of the plastic. If so, give it a file smooth with a nail file, wipe it clean and try again. The rough edge could be catching the threads.
Posted on Mar 14, 2011
Bottom thread is a tangled mess. Was going great, now can't sew.
bottom thread mess is an indication that the needle thread tension is too loose
check the needle /hook timing to ensure that it hasn't altered
Jun 28, 2015 | Singer 6180 Brilliance 80-Stitch Sewing...
Thread is getting tangled in the bobbin chamber of my brother xl3125 when I sew. When I pull the fabric out, several strands come out of the bottom and the bottom side of the sewing is tangled and loose. ...
try these suggestions
change the needle
rethread the machine top 7 bobbin ---make sure the presser foot is in the up position before rethreading--use every thread guide
clean under the needle plate & in the bobbin area for lint
make sure the thread has not come off the thread take up lever
make sure the bobbin is turned the right way in the bobbin case & that
the bobbin is not over full
Sep 27, 2012 | Brother Sewing Machines
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
My machine will only sew a stich or two then the motor still goes, but the feed dog and needle get stuck like the top thread is tangling with the bobbin. How can I fix that?
check you needle to see if it's damaged
check to see if the top thread to see if it's come off the thread take up lever
check to make sure there's no lint or loose thread in the bobbin area
Sep 30, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Elna 6003 quilters dream isn't sewing properly. It makes one stitch and then jams around the bobbin and presser foot area. I wish someone would post a free copy of the instruction manual because I can't...
This is the only one I could find and it is $10.00 http://www.mcssl.com/SecureCart/ViewCart.aspx?mid=F506721D-3C9E-481E-8B3F-7E1C3114072F&sctoken=0465a6a54d8e482581a12d868a00a3fb&bhcp=1
The reason for the jam could be the fabric is thick and this causes the foot to raise to the point the the tension is open that the top thread is feeding erratically.
Another could be the bobbin area needs to be cleaned.
Lastly, it could be the timing needs to be adjusted and this means a trip to the sewing machine dealer for service.
Apr 28, 2010 | Elna Quilter's Dream 6003Q
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Jan 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Bobbin tangle
can not thread bobbin...bobbin on top
Jan 16, 2008 | Kenmore 19233 Computerized Sewing Machine
Needle Thread and Bobbin Thread
This is a timing problem and will have to be repaired by authorized dealer.
Jun 18, 2007 | Euro-Pro 373 Mechanical Sewing Machine
Sewing Machines Logo
190 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
