Okay, so i plugged my xbox in and then i plug it into the tv, but no picture pops up at all, it says check cable signal, but i don't know what cable, and i tried hooking it up in the 1 component(under the 2 cmponent because there's only 2) can u tell me what "check signal cable is" or help me out please?
    President:
  • 1,623 Answers
What colour are the plugs on the lead you are using, if you have a component lead it will have a green a red and a blue plug if its composite you will have a red white and yellow plug
Posted on Mar 12, 2011
My xbox 360's wires are all plugged in the correct places and other people can see my xbox profile when i turn my xbox on but on my component source on my tv it says no signal so i can not get a...
If you have the AV cable that has the switch on the Xbox end, make sure that it's in the correct setting. Your cable could have shorted out if this does not work.
Aug 17, 2011 | Microsoft Xbox 360 Console
I recently bought an HDMI cable for my xbox 360 (the new type, i don't know if it has a name but its the one with the touch sensitive power button), and when I plug the cable into the xbox and the tv...
Sorry to hear about your trouble. You elimanted the cable as a potential problem so that is good. You are left with a couple of options that might be causing the problem.
-Bad HDMI port on the XBOX
-Bad HDMI port on the TV
-Incorrect TV settings
On the TV, you want to make sure you set it to the HDMI input when you are using HDMI, but I assume you already do this and most newer TV's will auto adjust to HDMI when the xbox is turned on. Always good to double check.
The easiest way to narrow the problem down further would be to test the hdmi connection with another TV. If the xbox works on another TV then you narrowed the problem down to the TV and will need to repair the TV either through warranty support, by yourself or via a TV repair man. If the xbox has the same trouble on a different TV then you know the problem is with the XBOX and you can contact Microsoft Xbox support for repairs.
Let me know if you have any questions.
Regards,
G33k
Jul 05, 2011 | Microsoft Xbox 360 Console
Trying to plug in my xbox and can get sound but no picture
Is this the first time you've tried plugging in your Xbox?
Is it Xbox or Xbox 360?
Try plugging it into another TV yet?
I've had a similar problem where I've manually set the resolution of my television on my Xbox. I had it set up for 1080p and then plugged it into my little CRT. The picture was all scrambled and I couldn't do anything. I had to plug it into another TV to fix it. This is the original Xbox by the way.
Check the settings on the Xbox, and if that doesn't work, try swapping out the cables or put it on another TV.
Feb 05, 2010 | Hitachi 57F500 57" Rear Projection...
XBOX 360. No Audio or visual,yet everything else seems okay
are you using and hd cord if so check your plugs make sure you are in the right slots then if hd cords there is a switch on the plug in to the xbox that needs to be switched to the hd setting
Jun 18, 2009 | Microsoft Xbox 360 Console
How I hook up an XBOX 360 to digital converter box (TV does have yellow/white/red jacks). Also have rabbit ears for antenna. Thank you.
you don,t , the xbox 360 will have component cables and posibly an hdmi output , but you can plug the component cables directly to the tv in a auxillary input and on your menu screen it will either say video1 or video2 or video 3 ,you can put the cables from your xbox into those inputs on the tv and as long as your tv is also at that input you should have a signal , hope this helps ,glenn
Mar 02, 2009 | Insignia Digital-to-Analog Converter for...
Hello my name is steve
1. Make sure the Cable is properly connected to the back of the Xbox.
2. Make sure the Cble is properly connected to the inputs on the TV (Color coded if using component or composite cables).
3. Look on the large part of the cable where it plugs into the Xbox. There is a switch with two settings: HDTV and TV. If using the component cables (Green, Blue, Red + White Red), turn the switch to HDTV. If using the composite cables (Yellow, White, Red), switch it to TV.
4. If the problem persists, contact Microsoft at 800 4MY - XBOX . It's a toll free number but it isn't 24 hour.
plz Rate"
Dec 17, 2008 | Microsoft Xbox 360 Console
Rear input connectors
Does it give you a "No Signal" on the screen, you may have to check the xbox and make sure you have it setup to output a HD signal. Let me knwo what you find.
Oct 26, 2008 | RCA Scenium D40W20 40" Rear Projection...
No signal
Okay the Ps3 has some problems with the 3 colour plug Red white and yellow the plug that connects from the tv to the Ps3 is the problem you should try to fix that plug it makes the screen go black rite?? so its that plug cuz i got that problem and its REALLY tiring going up to it and fixing it.
Click the Thanks Button please :D
I tried to help atleast
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
Bad connection?
Cant get picture, sound working. new cables has 5 plugs
Feb 23, 2008 | Microsoft Xbox 360 Console
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
