Question about Cisco AIR-AP1121G-A-K9 802.11g/b Wireless Access Point
How to reset password to access AP Cisco configuration.
  • 3 Answers
To reset the password if you have forgotten it, you must reset the whole thing to factory settings, which means you must reconfigure everything. This involves the mode button which is the little button to the right of the ethernet and cable lock slot, this will require a pencil/pen: 1. Disconnect the power to the access point 2.Plug the power cable back in and at the same time hold in the mode button 3.Hold the button for about 3 seconds until the light turns amber 4.Wait for it to reboot and you should be able to reconfigure like it was brand new
Posted on Mar 13, 2011
  • 32 Answers
Connecting to the AP
To connect to the Access Point, follow the steps below:
  1. Use a straight-through cable with 9-pin-male to 9-pin-female connectors to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the AP.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe Microsoft HyperTeminal; other programs are similar.
  3. In the Connection Description window, enter a name and select an icon for the connection and click OK.
  4. In the Connect To window, use the Connect using pull-down menu to select the port to which the cable is connected, then click OK.
  5. In the Port Settings window, make the following settings:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: Xon/Xoff
  6. Click OK.
  7. Press Enter.
If there is any problem with it...then contact http://www.vtechsquad.com/cisco-wireless-routers.html and get all your router related issues fixed.
Posted on Aug 02, 2011
Can get router to work
The Cisco Aironet 1200 access point provides secure wireless connection to your network. Cisco's wireless access design meet the needs of a small to medium size business.
This unit provides secure network access for laptops or Wi-Fi capable portable devices, which you upgrade at any time as your business grows.
A beneficial feature of the Cisco Aironet 1200 is its ability for the administrator to reset the access point remotely.
This resetting process works through your internet browser.
Log on to the System Configuration page by entering your Cisco Airnet 1200 IP address in your browsers web address text box.
Enter your user and password information from the pop up menu.
Click on the "Setup" button from the summary status page.
Select the "Cisco Services" setup option and click on "Manage System Configuration."
Click on "Reset All System Factory Defaults" to reset the router.
The Cisco Aironet 1200 will be restored to factory defaults.
http://www.cisco.com/en/US/products/hw/wireless/ps430/index.htmlCisco Aironet 1200 Series
Configaration Cisco Aironet 1200 Serieshttp://www.cisco.com/en/US/docs/wireless/access_point/1200/vxworks/configuration/guide/bkscgc10.html - wp1016665
May 07, 2014 | Linksys Cisco Aironet 1200 Wireless Access...
Cisco Acces Point series 1020 Air-AP-1020-A-KG
This is an enterprise AP and needs to run with a Cisco router.
Mar 30, 2014 | Cisco Computers & Internet
Reset Access point Cisco 1020
If your current controller can't see the AP, then the 1020 can only be reset through the Controller it was originally configured with. It doesn't have a console port, so you have to connect it to the old controller and run "clear lwapp private-config"
Mar 25, 2014 | Symbol Spectrum24 4131 Access Point...
When I enable the vlan option in an EAP9550 I lose wireless access
Bruce,
Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is 10.0.10.0/24 while AP2 uses VLAN 20 with a 10.0.20.0/24 subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address 10.0.10.1/24 while the second SVI can be configured with 10.0.20.1/24 for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
I hope this helps.
Mar 13, 2014 | EnGenius Computers & Internet
Reset cisco aironet 350 adapter
Try Putty and a 9pin male to RJ45 RS232 serial console cable.
the instructions are in the link provided here:
http://wirelesslanprofessionals.com/wp-content/uploads/2010/01/Password-Recovery-on-Cisco-APs.pdf
Jun 30, 2017 | Computers & Internet
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
I forgot to change the default public credential User: cisco and pwd: cisco. Un fortunately I did restart the router. I would like your assistance to gain access to the router or to reset it back to...
Here is a cisco page that goes over the password recovery procedure. Once you reset the credentials, you can make any configuration changes needed. You will also have the option to keep the existing configuration in place but change the password, if the configuration has any use to you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
Mar 11, 2011 | Cisco (1841) Router (cisco1841)
Cisco Aironet 1200
if u have an cisco acs and windows AD, i'd configure the ap to point to acs and configure acs external db to point to AD. let ur windows dhcp server hand out IPs to your mobile devices.
Feb 18, 2008 | Cisco Computers & Internet
Configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cisco AIR-AP1121G-A-K9 802.11g/b Wireless Access Point Logo
1,353 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
