Question about Electrolux Epic 6500 Vacuum
Electrolux Epic 6000 SR - what do the lighted icons on the top of the case mean? Vacuum goes on, then stops.
  • 44 Answers
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Posted on Jan 01, 2009
plaintiger
  • 9 Answers
SOURCE: Electrolux Epic 6000 SR Owners Manual?
oh, and as far as i know there's no secondary filter on this machine. or at least if there is, ours hasn't needed any tending to in at least ten years or so...
Posted on Mar 08, 2009
SOURCE: cord won't rewind. How do I take apart to repair?
see jan 1, 2009
Posted on Apr 19, 2009
  • 430 Answers
SOURCE: what does the warning light with question mark
It means to check the bag. Your bag is either missing or misaligned and has slipped past the little clear sensor or bag lockout plunger in the corner of the bag chamber at the door.
Remove the bag turn on the vac and push this switch, the vac should start when the switch is depressed. If not the internal switch inside the vac is misaligned or damaged. Please post back to confirm how you make out
Posted on Oct 14, 2009
SOURCE: electrolux vacuum epic 6500 sr shows a lighted
clean filters and ducts
Posted on Dec 13, 2009
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Electrolux 6500 sr what do the symbols on top of the canister mean when they are red?
the red symbol probably is the temperature light.This means you motor is over heated.Check hose,wand and power head for a block...Chris
Jun 06, 2014 | Electrolux Epic 6500 Vacuum
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
I have the electrolux vacuum epic series 6000 SR and bought it used therefore I dont have a manual. I have had it for about a yr and it worked great..it looked like it should have a filter but I didnt...
1. A manual can be downloaded from:
http://www.aerusvacuums.com/support/manuals/.
The Epic 60006500 is located under "Older Models". Download the Epic 6500 manual
2. Check for clogs in the hose and the power nozzle inlet.
3. Disconnect hose. Turn on vacuum. Does it run? If so, place hand over intake? Did it shut off? If it did, the problem is a worn out or broken component inside the vacuum. Generally a result of using generic "made to fit" Electrolux bags. This is a part that needs to be replaced in an authorized Aerus (Electrolux) shop.
Sep 15, 2010 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
Mar 10, 2009 | Electrolux Epic 6500 Vacuum
Jan 05, 2009 | Electrolux Epic 6500 Vacuum
Electrolux Epic 6500 SR series
Ok i found a solution for my Electrolux Epic 6000 which had the exact same symptoms as you describe. I fixed it by disabling the "bag full sensitivity adjustor" (BFSA for short, for the lack of a better term). For that i opened the case, removed the hose that was preventing me from opening complety the casing, unscrewed the transaparent BFSA mechanism.
Here's the walkthrough:
- Open the case: Open the top part of the vacuum (where the bag is)
- Remove the 2 side rubber by sliding them from the back to the front of the vaccuum
- Remove the "plastic cap" at the end of the vacuum (you can slightly lift the vacuum top part to make it easier)
- Now unplug a small air hose to be able to open the case completely.
- Find the BFSA device and unscrew it.
- Now give your vacuum a try... it worked for me.
Nov 27, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
274 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
