Question about Whirlpool LEW0050P Electric Dryer
I am trying to replace the drive belt on a Whirlpool dryer model # LEW0050PQ2 belt part #8183101. This should be a simple task but once the belt is around the drum it is about two inches too short to reach the drive motor - suggestions please.
    President:
  • 3,074 Answers
Http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Posted on Mar 13, 2011
  • mattthomp104 Sep 04, 2011
    I just solved this problem. I used a 9/16 deep socket and a 2" extension (a longer extension won't fit.) Slip the socket over the motor shaft and the belt over the socket (it was just long enough with some stretching) and use the extension to lever it down, sliding the belt off and rotate the drum to set the belt.
How to change the belt on a whirlpool AWZ7814 AL
These dryers have common roots with lots of other brands. You should be able to see what you need via either video:
How to Change Dryer Belt on Whirlpool Dryer or in Instructables
How To Replace Dryer Belt on Whirlpool Models
Nov 18, 2015 | Whirlpool Dryers
How do I fix a drive belt to a kenwood KVT1W tumble dryer please
Hello Linda;
My name is Peter. I am a retired field service appliance technician.
Go into the following web link. It is not for a Kenwood but the base tasks are there. Whirlpool Kenmore Dryer Repair How to Remove and Replace Belt 341241
Jun 08, 2015 | Dryers
My dryer heats up but the drum does not rotate im going to try and see if the belt has broken any other suggestions?
Most likely belt has broken. Once in awhile, the belt will work its way off if you had weird loads like shoes or something. The other likely possibility is the motor. Motors are very simple to replace as well.
Jan 13, 2014 | Dryers
Replace drive belt
This is a pretty simple DIY repair that can save you a bunch of money by not calling a repairman to do it for you. Here's a comprehensive how-to video showing how it is done on a Whirlpool dryer.
Your brand dryer may be different - but should have a very similar belt replacement procedure. If you'd rather see a video for your brand / model, have a look here for available belt replacement videos for other brands.
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 16, 2011 | Dryers
I'm installing a drive belt on a Whirlpool LEW0050PQ dryer. I've opened the back of the unit to expose the drum and drive motor. The new belt, part # 8182481, will have to stretch at least 3" to...
if it is a rubber belt like a big "O" ring it is necessary to warm up the rubber by stretching it (like you are building up your abs)
it will be tight to fit but it will go on
Jul 02, 2017 | Whirlpool LEW0050P Electric Dryer
How do I replace the belt in my dryer? It looks simple enough, but I want to be sure. Mod.NED52402Q0
The model number you provided did not cross reference to anything. I did find the number "NED5240TQ0". If this is your model number, the following steps explain how to replace the belt:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. Release the belt tension, by pushing the idler pulley (tensioner) to the right (away from the belt) and remove the old belt from around the drum.
If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and push the wheel to the RIGHT while pulling the belt over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for WHIRLPOOL and refer to diagram H (This model Amana is manufactured by Whirlpool).
Replacement parts (if required) can be ordered on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
The part number for a replacement belt is 341241. All these sites offer great service with competitive pricing, so shop and compare. The first three sites I have listed also inlcude helpful exploded view diagrams that can help you locate and properly indentify the parts you may need. you can view a diagram of the belt and tensioner under the "Cabinet Parts" section. The belt is listed as item 30 and the tensioner is listed as item 29.
NOTE: If you still have the teflon glide type tensioner, Whirlpool recommends you replace it with a conventional roller type idler pulley. The teflon type tensioners caused premature wear to the drive belt. The part number is 691366.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws.
NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them. If you have any questions about this repair, please post back and let me know. I hope this helps you.
Aug 04, 2010 | Amana Dryers
Replace Dryer Door Switch
Have you checked the dryer belt? The belt can also prevent a dryer from running. In either case you will need to open the dryer to access both components. this is accomplished by lifting the top panel and/or removing the dryer front.
If the model number is correct, just follow these steps:
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing. The part number for a replacement switch is 3406107.
NOTE: At this point you can access and remove the door switch and replace a necessary. If you don't see the dryer belt wwrapped tightly around the drum, there's a good chance it is broken. Continue on with the next steps to replace the belt.
You should now have complete access to the dryer interior. If the belt is broken, this may cause the idler pulley (tensioner) to come loose. This is normal with no tension on the pulley to hold it in place. To install a new belt (if required) and re-install the pulley, follow these steps:
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Roper and refer to diagram H.
repairclinic.com
Jul 04, 2010 | Whirlpool LER5636P Electric Dryer
How to replace the belt for a whirlpool ler5620kq1 dryer
It is a very tricky task to put this belt on but I think I can work you through it. When you get the belt around the drum and get to the idler, push the belt under the idler wheel and through the forks of the idler pully assy. attaching it to the pully on the motor. Tension should be on the idler pushing the wheel up toward the drum. Hope this helps.
Apr 01, 2009 | Whirlpool LER5636P Electric Dryer
How do you replace the drive belt on Whirlpool dryer?
What is the model number of the dryer.
Nov 14, 2008 | Dryers
Whirlpool LEW0050P Electric Dryer Logo
345 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
