Question about Homelite Garden
Homelite string gas trimmer Model ut20811A: 1. Will start with full choke and run with full choke for a while but will not maintain speed when choke is released. 2. String feed will not feed when taped. String gets wrapped under adjacent loop on spool. Have tried to wrap new string tightly on spool to no avail.
  • 2,019 Answers
If it only runs with choke on, then mixture is too lean or idle set to low.
Adjust mixture initially at 1.5 turns, then move in or out as needed for highest idle when warm.
Make sure no leaks or clogged filter when adjusting.
Hard to say with string feed, but are you sure you are not putting the spool in backwards?
Posted on Mar 12, 2011
Homelite very hard starting prime 10X full choke model UT32651
Make sure your fuel mix is fresh and of the right gas-oil ratio. Today's pump gas has Ethanol mixed with the gas and can go bad in as little as 30 days. this stuff is terrible to run in small 2 cycle engines. A lot of loggers I know buy Ethanol free gas for their saws. Also do not ever use starting fluid to start a 2 cycle engine ! What happens is the Either washes the cylinder wall of oil and now you have a scored piston and/or cylinder
Apr 03, 2014 | Homelite Garden
My 26HT reconditioned trimmer will start and run on full choke but, if I take it off to middle choke, it dies. It doesn't run right on full choke but does rev up enough to engage the blades. Has...
sounds like a carb problem You will have to take the carb off and strip it down to parts clean out all the ports with a good cleaner I use brake clean reassemble and reset the High speed and low speed jets at 1.5 turns out then adjust from there
Jun 14, 2011 | Homelite Factory Reconditioned 26cc...
My homelite string trimmmer will not run when choke is run position. it will run, but not at full throtle, when choke is set between full choke and half-choke.
you've got a fuel system issue , most likely carb problem, if this a newer trimmer it will likely need the carburetor replaced or adjusted, also check for cracking fuel lines or signs of old fuel varnish in the tank
May 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Trimmer will only run in choke position
You have a few possibilities. Make sure you have good fresh gas in the tank. You're not getting enough gas, so choking helps get more gas than air, making it run better. Could be the carb diaphram (not very expensive if you replace yourself), when they get old they don't perform like they should. Could be the filter in the gas tank is bad, plugged. Also might be just an easy adjustment on the carb Low, and High speed screws. The choke has three positions, full choke, partial choke, and no choke, which means run position.
Apr 28, 2010 | Homelite Consumer Products 4.0 Amp, 13 In....
Trimmer won't stay running
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Aug 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
St185 Homelite string trimmer starts then dies
I resolved my problem by taking apart the carborator and cleaning it. There were clogged passaged that had stuff come out of them when I used airisol carb cleaner to blow them out. I only had to make one gasket the carb mount gasket which is pretty basic only 5 holes.
It ran for the next 3 hours, ran fantastic!!!!!!
Jun 13, 2009 | Homelite Garden
Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
139 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
