Question about HP LaserJet 4600dn Color Printer
I have an HP 4600 and I recently changed the Black Cartridge and printed less than 10 documents and now it states toner is not seated or catridge is missing and it wont print at all. It will state printing job... but nothing happens.
  • HP Master
  • 1,915 Answers
Reinstall the old cartrige that you were replacing and see if it is recognized. If it is then the problem is your new cartridge not the printer. Take the new cartridge back to vendor and get them to replace it, which they should do if they are reputable.
Posted on Mar 12, 2011
Hello, My epson printer doesn't print the scales of grey right. It prints black, but the scales of gray look like green-blue. Thank you PS The ink catridges are new.
Have you recently changed the black cartridge with a non-standard or remanufactured cartridge? I'm having the same problem with my deskjet and it started when I changed my Black cartridge for a non-HP refill.
Dec 21, 2010 | Epson Stylus 1400 InkJet Photo Printer
The left side of documents received do not print. How do I correct that?
I've checked my 3055 service manual and do not see this particular error as you've described it; I do have a couple of suggestions which may be helpful.
Since only half the page is printing, this implies an error with the print cartridge itself, it may either be low on toner or it may be damaged.
Does this error occur when you are printing documents from your computer or making copies as well? or does it only occur when you are receiving faxes? If the error is occuring regardless of what you are printing (or copying) and from received faxes I would have to conclude an issue with the toner cartridge itself.
You can visually inspect the cartridge by pulling back the plastic cover part and see if the roller shows signs of damage. If so, replace it.
Try shaking the catridge back and forth to even out the toner inside; If the cartidge is low on toner it's possible that what remains is only on one side.
Inside the printer, below where the cartridge sits is a black colored, somewhat spongy roller. This is called the transfer roller and if it's damaged it could be the cause of your print quality error.
Lastly, I would try a new HP cartridge, stay away from the generic brand ones as they tend to have a much higher failure rate and do not come with the HP warranty.
I hope this helps!
Sep 01, 2009 | HP LaserJet 3055 All-In-One Printer
HP 4550 Color Laser jet reports no "errors" yet does not print
HP 4550 Color Laserjet Printer - Blank or white pages :
01. Your software application is sending an extra page-eject command.
02. Check the software’s printing configuration information. There is a problem with the network configuration.
03. Some sharing devices on networks may generate a blank page as a separator.
04. Check with the network administrator.
05. The printer may be feeding two or more pages at once because the paper is difficult to separate.
06. The sealing tape has been left in the toner cartridge.
07. The toner cartridge is empty or defective.
08. The laser scanner door does not open properly.
09. Remove and reseat the toner cartridge.
10. Check the laser scanner shutter door for proper operation.
11. The toner cartridge guide is damaged,
improperly positioned, or missing.
12. There is no transfer roller voltage.
13. Perform the Half Self-Test Functional Check to check all other electrophotographic processes.
14. Replace the transfer roller if necessary.
15. The high-voltage connectors are mounted on the high-voltage power supply (HVPS) PCA and protrude into the toner cartridge cavity.
16. Check the springs for functionality. Clean if dirty; replace if defective or missing.
The HVPS PCA is defective.
17.The DC controller PCA is defecti  There is no drum ground path.
18 Check the drum ground.
19. The laser scanner cable assembly is defective
20 The page length and margins are not set correctly for the paper size. Verify that the ribbon connector at J1307 of the HVPS is
properly seated.
21. If the HVPS has been removed recently, verify that the ribbon connector from the DC controller PCA to the HVPS is properly
seated at both ends..
22. Verify that the photoconductive drum is rotating properly. Perform is the drum diagnostic test to visually observe if the drum is rotating.
23. OR using a felt-tipped marker place an index mark on the edge of the drum outside the image area. Turn on the printer (wait for
drum rotation to occur), and then look to see if the drum has
24. moved. If the drum has not moved, investigate the mechanical
and electrical drum rotation circuitry and movement mechanisms.
25. The imaging drum shutter may not be retracting. Replace the imaging drum.
26. Lst but not the least, please fry to have the Printer int the Setcie
27. Use only HP Authorized Genuine catridges only
Jul 21, 2009 | HP Color LaserJet 4550 Printer
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Hp Laserjet 1018
change the cartridge and try it
Feb 24, 2009 | HP LaserJet 1018 Printer
HP L7680 Print Problem
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer..
Good Luck
Jan 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp 4600 no cyan printing
Firstoff, if you have tray 1 set to "any size" & "any type" they had problems with it going into calibration to frequently. If you upgrade the firmware this will take care of that. As for no Cyan, check the scanner interlock to insure it is opening the scanner cover. You could also go into diagnostics and disable cartridge check and swap the cartridges around, ie. cyan & magenta, run the print quality pages and see if the problem follows the cartridge. It could also be HV power supply.
Jun 18, 2008 | HP LaserJet 4600dn Color Printer
Printer is printing black line
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
Mar 07, 2008 | HP LaserJet 4 plus Printer
HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Jan 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP LaserJet 4600dn Color Printer Logo
102 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
