There are two vertical lines on my monitor one is red and other is green
  • 56 Answers
You may have several issues, lets try to narrow down whats wrong. When you see the lines hit the print screen button. Then go into Paint and select paste, this should make an image of whatever was on the screen when you hit print screen. Are the lines still there in the same spot? If so check the cables between your monitor and the PC. If not it is your monitor, check around for magnetic devices near the monitor if you can not find any the monitor may be bad.
Posted on Mar 12, 2011
What is the cause and is there a fix for the two vertical lines in the center of my LG monitor.
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 11, 2014 | LG M4225CCBA 42 LCD TV
Vertical green line screen try
Have you tried to do a reset via the monitors menu options?
Jan 21, 2014 | HP w1907 LCD Monitor
Colored vertical lines on my monitor
Depending on the age of the monitor, it most likely will be Capacitors that are leaking. I have repaired many different brands of monitors and have seen problems very similar to yours. 99% of the repairs I do are capacitor Issues. It's well worth replacing them IF the screen is still in very good shape as far as brightness and contrast. most repair kits usually cost between 12 and 20 dollars.
Hope this helps!
Dec 08, 2013 | Acer Computers & Internet
LCD display problem
Are you sure the cable is properly seated? You will typically get a tint of red green or blue when a particular pin on the cable isn't making contact. The lines on the other hand would indicate a bad display. Best advice would be to check the cable and if its all the way in hen replace the monitor. They are not worth repairing and also dangerous to work on.
Nov 24, 2013 | Sharp LC 37A63M 37" LCD Flat Multisystem...
Vertical Lines Dell Ultrasharp 2001fp
Sorry to say that it is a permanent damage of your monitor screen. Usually you can do nothing. But if you want to change the monitor screen, you have to visit a monitor & television specialist.
Cost will be 1/4 of a new monitor.
Sep 22, 2017 | Dell UltraSharp 2001FP 20.1" LCD Monitor
There are two vertical lines on my lg flatron w1942s monitor one is red and other is green line
Go to the buttons on the bottom of your monitor it will give you an option to change the vertical and horizontal setting.
Mar 12, 2011 | LG W1942S 19" LCD Monitor
Vertical lines in my laptop screen
if this line is there during boot up then it is a monitor problem usually. but if it is not then it is a problem with your windows files. you could try reinstalling your windows from the disks you were given with it? otherwise i will look into it. email me if you need more help. milliprowd21@yahoo.co.uk
thanks
matt
Jul 30, 2008 | Acer TravelMate 2300 Notebook
Thin Vertical Stripes
THESE ARE DEAD PIXEL LINES IN DISPLAY REALLY NO FIX
Jan 23, 2008 | IBM 2704hb7 (Black) 19 in. Flat Panel LCD...
VERTICAL COLORED LINES ON MONITOR
Your panels are dying.
Well more to the point the driver tabs that run the panel are dying and are not going to be cheap to repair for either case.
For the stand alone LCD, it is cheaper to get another one.
For the laptop, find a laptop on Ebay or similar with a dead motherboard and swap out the screens, also gives you spare parts for the laptop. If you goto a repair shop and get a screen it will cost you as much as a new laptop.
Nov 24, 2006 | Dell E171FPb 17" Flat Panel LCD Monitor
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
