Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
Im trying to find the brushes for my electric motor for my husky air compressor vlh1583009.01
2 Suggested Answers
  • 1383 Answers
SOURCE: im trying to find brushes for my electric motor in
I have not been able to find brushes for your type of compressor. I find a close match on ebay and shave/sand to size. Measure your brushes. Search ebay for "carbon brushes" looking for best price and size needed. Make sure that the armature is still good because the brushes will wear very fast if arm. is bad. Good luck
Posted on Feb 15, 2011
How do you replace a belt on ***** air comprester
Most modles you can either loosen the pump or the motor and slide them together. the belt should roll right off.
Sep 15, 2014 | Husky Air Compressor. 2 Gal. Portable...
Motor cuts off before reaching 125 psi
Im guessing this is a recip (piston Compressor) Sounds like your pressure switch may have adjusted itself by vibration. Take the cover off the pressure switch, there should be 1 or 2 screws on the top, one adjusts the pressure, the other adjusts the differential pressure (There may just be one) turn the pressure screw in the direction of the +, you need to do trial and error on this, turn it 1/4 of a turn, then switch on, see what the pressure gets to, then switch off, drain some air off, then adjust as necessary until you get your required pressure. Hope that helps
Aug 31, 2012 | Husky Air Tools & Compressors
I need new brushes for a Bostitch CAP2000 air compressor. Anyone know where to find them?
The brushes for the type of motor in your compressor are not sold seperately as a part. If all you need is the brushes to get it going again your best bet is to find a power tool service center or someone that works on electric motors to see if they have something close that will work or can be adapted to work in your motor.
Feb 01, 2012 | Air Tools & Compressors
Hi i have an Ingersoll rand 80 gal, 7.5 hp, model #2475 air compressor and the electric motor is arcing when trying to run then blows the breaker. Any ideas? thanks
It sounds like either a problem with the brushes in the motor or the engine shaft is jammed. Have you on many previous occasions run the compressor on that circuit with no problems? It may be as simple as the breaker is not sufficient for the power draw of the compressor.
If you have had the unit for awhile and it has been run lots and the engine shaft spins easily when turned by hand (unplug first) then it may be an issue with the brushes on the electric motor. Take the engine apart and replace the brushes with new ones from an electric motor shop. Take pictures as you disassemble the unit so you will be able to refer to them when it comes time for reassembly.
If the motor shaft does not turn by hand, remove the belt that connects it to a compressor and try again. If this works, reconnect the power and see if the electric motor now works with power on and the belt off. If the motor works and there is no short to throw the breaker, then your compressor is in need of a rebuild and that will cost money and time.
Mar 15, 2011 | Ingersoll Rand Electric Driven Two Stage...
Im trying to find brushes for my electric motor in my husky air compressor mod# 417-270
Feb 13, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
May 27, 2010 | Air Tools & Compressors
Husky Wl6510 air compressor, motor shuts off
One other possibility is that the check valve between the compressor and the tank is letting air flow back against the compressor. Is it having trouble restarting when the pressure lowers to the cut-in pressure? If it doesn't want to start up again, sounding like it's starting against pressure, suspect that valve.
Dec 13, 2009 | Air Tools & Compressors
I need motor brushes for model# H1506FWH Husky 1.5 HP pancake compressor.Where do I get in the Mobile, AL area?
First you have to understand something important about motor brushes. That is the only difference between all motor brushes is their size (brush diameter and contact wire length). This includes fan motor brushes, water pump motors, power tool motors even automobile alternator brushes.
You can also find brushes where you might not think to look.
If you can get even close to the same size as the old set you can file the new ones down to fit. I've done it time and time again.
Your best bet is automotive electronic stores. However you might find them at local auto parts stores, hardware stores like Home Depot (look in the section where they have all the small parts bins). You might also try Tractor Supply. I know they are in Alabama but not sure if there is one close to you.
Remember you can modify the length of the wire also. If the old set has a small contact point on the end of the wire just remove it and solder it to the new brush wire.
I hope this helps you out.
Nov 18, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
