Question about Tools & Hardware - Others
Urgently need planer blades for a Metabo ADH1630W Planer. Can't seem to locate any, can you advise please?
Hi did you find any as I also need some
Cheers John
Posted on Sep 04, 2013
muttandjeff
  • 359 Answers
SOURCE: planer is not feeding wood through without manual force
maybe trying to take off too much with one pass try one sixty fourth and see if it does better , if so repeat process i have dewalt i take small amounts does fine get to heavy leaves black marks try it
Posted on Dec 05, 2008
rowdy45176
  • 2176 Answers
SOURCE: FITTING DETAILS FOR MAKITA PLANER BLADES
It depends on the planer blade set that you are using. If you are using the the 2 sided blades there is a guage that goes with it to set the blade depth before installing. I would strongly recommend that you go to Makitatools.com and type in your model number and download a copy of the owners manual for specific instructions. Let me know if you have any problems finding them
Posted on Mar 09, 2009
SOURCE: Seeking spare blades for RYOBI TOWA Hand Planer
Planer blades L-120N available on ebay from User ID:byarose2005
Posted on Jun 10, 2009
  • 58 Answers
SOURCE: need manual for dw733 planer so i can change the blades
Go here they have the manual in PDF form. (Download from web site):
http://www.dewalt.com/us/service/instruction_manuals.asp
Posted on Jun 19, 2009
SOURCE: Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
Posted on Oct 18, 2009
I own a Sears Power Planer Model 315.17320. Last week I bought new blades, part no. 17326. To install these blades correctly, I need a Blade Adjustment Plate - P/N 1-606871-01. I have been unsuccessful...
It seems that sears has dropped most of the parts for your planer. I can tell you in 2 minutes. Raise the front of the planer up as far as it will go to get it out of the way, Put the planer in a vise by the handle, take a straight edge, like a rule, or square, Put it on the flat rear of the planer bottom, bring the cutter around with a new knife set in there loose but snug, adjust your leveling screw so that the knife just scrapes the straight edge, doesn't pick it up and doesn't pull it, but scrapes it. do the left side, right side, go back to the left, then tighten it up. It is very important that both knives are set the same, so do the other side that same way. Make sure they are all tightened up. Don't answer the phone, You should be all set, hope this helps.
May 24, 2010 | Garden
I do not have a manual for my mastercraft maximum 13 inch planer and would like to know how to remove the blades for sharpening
If it is anything like my 12 1/2 inch mastercraft planer you will need to remove the dust guide first, and then the drum with the blades will be visible. To remove the blades you need to loosen the bolts with the appropritate sized crecent wrench. Seems to be the only part of my planer that does not require an allen wrench actually.
Oct 20, 2009 | Tools & Hardware - Others
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
May 16, 2009 | Tools & Hardware - Others
Help i need to change my Dewalt DW733 Planer Blades i lost manual
try dewaltservicenet.com They have manuals as well as parts breakdowns.
Apr 16, 2009 | Delta TP300 Shopmaster 12-Inch Portable...
Mar 08, 2009 | Makita Planer Replacement Blade, 3 1/4"
Planer is not feeding wood through without manual force
I had the same problem...sometimes you have to take the smallest amount off (1/64th) and it might work, otherwise your blades are probably dull. Try to feed the boards through the planer towards the sides, not just the center so they wear evenly across the length of the blades. They wear out very quickly, which makes this planer very frustrating. If you take the top cover off and inspect them, you'll probably see nicks in them and it's time to replace or rotate them. Each blade has two sides you can remove all the screws using the T-handle wrench from the top cover and flip them. Also, as the blades begin to wear, the planer will become louder and louder. That's another way to tell. When you install new blades notice how much quieter it is when you plane boards.
Nov 13, 2008 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Planes Safety tips
* Always wear safety glasses when you use a power planer. * Keep blades in your planer sharp. Never remove any debris or touch the planer blade if it is plugged in. * Always clamp wood to a sturdy surface when you use a power planer.
Aug 27, 2008 | Bailey Stanley 12-920 - Block Plane
Planes Comparison
If you have a stack of hand planers and you do a lot of woodworking, you might want to buy a power planer. Power planer have a number of qualities that should convince you to keep the old hand planers but add that power to the group. Choose a power planer when you have a lot of planing to do. One thing about a power planer is that it is much faster compared to the hand planer. Use a power planer when you need to make rabbets or even scrolling. The power planer can do both of these jobs. There is a great deal of versatility about a power planer. Keep the cut smooth with a power planer. Frequently a hand planer needs to be lifted and started again. This leaves gouges and groves. A power planer has a continuous blade that leaves a smoother cut. Get more precision. The continuous motion of the hand held power planer and set depth cuts the specific amount that you want. Plane larger areas. You can plane doors quickly and easily with a few strokes of the power planer. Straighten a board easier with a power planer. You also can create chamfered surfaces with the power planer.
Aug 27, 2008 | Rockler Carbide-Tipped Radius Plane &...
Tools & Hardware - Others Logo
48 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
