Question about Sony Bravia KDL40HX800 40 in. LCD 3D HDTV
My sony hx800 automatically turns off after 2 min of watching.. then the standby mode blinks six times in a row after 3 seconds.. what should i do?
HDTV GURU
  • 261 Answers
SOURCE: Sony BRAVIA KDL-52W3000
I would take that puppy back to store and get exchanged out. According to lemon law. Let me know what happens. Thank you Jay.
Posted on Feb 01, 2008
  • 84 Answers
SOURCE: sony bravia 46''
It sounds like it is defective, you have warranty call for service!
Posted on Jun 15, 2008
mistersony
  • 320 Answers
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Posted on Nov 10, 2008
  • 108 Answers
SOURCE: Sony Bravia turns off by itself
Replace the BU Mount pcb. Sometimes they are called the FB pcb.
Posted on Jan 08, 2009
SOURCE: Sony KDL-40V3000 standby blinks 13 times.
A service technician arrived at my home this morning and infromed me that 13 blinks indicates a bad LCD panel. His quote to repair it was approximately $500 more than the TV initially cost. I contacted Sony support directly, and they have agreed to replace the TV, since it is less than 30 days out of warranty. The KDL40V3000 has apparently been dicontinued so they are replacing with a KDL40V4100(factory reconditioned). I know this won't necessarily help others with the same problem, but if your warranty ended recently enough they will probably work with you to mitigate the expense.
Posted on Feb 20, 2009
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
I have a Sony KF 50 WE 610 projection screen TV. It has worked perfectly since I bought it six or seven years ago. This morning I turned it on and the sound came on for a second, but then the sound went...
Hello
Five consicutive blinks at a time and the stops and again blinks five; is its self diagonosis procedure. All modern Sony sets has this function included in its circuits. If the system control IC inside it detect any fatal fault inside its circuits system, it will give a signal to its power control unit to shut it down its high voltage outputs to protect the other components from further damage. In your set; as Sony describes; I quotes:-
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Actually the components marked in numberes will not be the same as in your TV. But the fault will it be.
    If you have enough knoledge in electronics and have a concept of soldering and have a good quality multimeter; youreself can do this work by home. OK
    Mar 19, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
    I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
    Mar 09, 2011 | Sony Televison & Video
    I was watching the news and it shut off on its own and will not turn back on. What do i need to check?
    If you include how many times the standby light flashes, that will give a fault location. Not to worry, here is a list.
    Hope this helps.
    • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
    • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
    • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
    • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
    • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
    • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
    Jan 23, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
    When i turn tv on green light blinks two or 3 times then goes back to red and never turns on
    We need to know what make and model to accurately answer this question, but if you have a Sony, here is the information -
    Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
    The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again. Here is a list of the problems that might have occurred indicated by the number of blinks.
    Jul 03, 2010 | LG 42PC3D 42 in. Plasma Television
    40'' Sony Bravia goes into standby with the light blinking 9 times
    I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
    Sep 30, 2009 | Sony Televison & Video
    Sony kds-r50xbr1 turns itself off and then green light blinks 52
    I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
    Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
    Power problem
    Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
    Sony kdf 55xs955
    Low B error protect is what 6 blinks means on the LA-3 chassis
    Jun 15, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
    Sony tv wont turn on, standby light just flashes
    I had the same problem guys! This is what I did:
    My T.V. wouldn't turn on. The standby light was flashing six times, then four, then seven...I called Sony and they told me to unplug it for a couple of minutes, then try it again...didn't work....BUT, I have found a solution:
    Try unpluging your T.V. for 4 hours+, then turn it back on. Worked for me! It's called a "hard reset" by sony. I had my T.V. unplugged for the whole day though.
    Nov 18, 2007 | Televison & Video
    Sony Bravia KDL40HX800 40 in. LCD 3D HDTV Logo
    230 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
