Question about John Deere Garden
How to attach snow blade & blower to model 318 John Deere Mower
3 Suggested Answers
  • 24 Answers
SOURCE: older john deere 5/20 snow blower won't throw snow very far (3-4ft)
Have the augers every been taken out, I have seen right and left sides switched and no it won't throw snow .
Good luck
Posted on Feb 17, 2009
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
I am looking for info on a John Deere snow blower with the serial number M00338X525454*. What year is it and what models does it fit?
I have been on a local dealers wed site on John Deere snow blowers for my own found it very helpful . this may help you local dealer was very up to date with the information I needed .
Nov 04, 2016 | John Deere Garden
I need to know how to wire the honda gx620 engine to the john deere 318 mower
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
1981 John Deere T400 Tractor Workshop Service Repair Manual
Apr 19, 2016 | John Deere Garden
My 318 John Deere mower blades would not turnoff. The switch would not move. Even when I got off the seat the mower blades continued. I turned the motor off and now it won't start. Any idea?
Faulty attachmentment switch, replace it as it is sending a signal that it is engaged to your starter circuit, that is why it wont start.
It is also faulty as it wont engage the attachment (mower cutting deck)
Aug 03, 2015 | John Deere Garden
John Deere X304 PTO Engagement Problem When Warm
Hi, check your belt tension, check all idler pulleys and drive pulleys for free rotation with the belt off and finally check that the belt is not bottoming out in any of the drive pulleys. If so, replace the belt. The blades should come up to speed imediately wether hot or cold and it sounds like your belt is slipping in one or more of the pulleys which drags the motor revs down until it grips. Regards Phil.
Jun 13, 2012 | John Deere Garden
John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
115 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
